| | #1 |
| Junior Member Join Date: Jun 2009
| New Peavey Vypyr 15 (problem?)
Greetings to all! First post here. I purchased this new Vypyr 15 amp today. I suspect the problem I am having is due to my unfamiliarity with the box. But can't be certain. I don't want to take it back (yet). Plugged amp in, and as expected the leds go crazy back and forth, side to side. Manual does have a sequence one can use to turn them off - for good, if they get too annoying. The other way to shut them off is to plug-in guitar. Well, I have a 6-string guitar on order, but don't have one here at home. I do, however, have a bass guitar. I realize you don't play a bass through a 'regular' amp. But for continuity sake, I plugged it in, and it did shut off the panning leds, locking them onto whatever corresponding number the particular knob is set to. The problem is - I get no sound. The bass vol is turned up, as is the amp's. But nothing! I have not yet heard a note from it. I select various presets on the amp, turn some dials, and still, plucking a bass string does nothing! Will a bass guitar not play even a note through a regular amp? I do have a 15w Peavey bass amp, and it plays fine there. So, hope just plugging the bass into the Vypyr didn't blow anything. Thoughts? |
| | #2 |
No, more likely a wire off the speaker or something. But you just bought it, it has a warranty, and that is what waranties are for. Take it back and show them it makes no sound. Let them sort it out under warranty. DOn;t go inside.
| | #3 |
Thanks Enzo. Tried again today, same result, initially. Yeah, I will use the warranty if I don't resolve this soon. Did some wiggling of the patch cable at the amp's "input" jack, and got some guitar sound. By moving cable around a bit, I got it to give me continuous sound now. But since the cable never hiccups when plugged into the bass amp, I am suspecting the new amp still. I will probably get a new cord and re-try. Although, as I sit here, I am thinking I should try reversing the cable aound, and see if problem remains. (everything's put away now). But again,thanks for the response. |
| | #4 |
Well, seems other end of patch cord does same thing. Again, even wiggling cord, no issues either end on bass amp. Well, gotta find sales slip. Thanks Enzo.
| | #5 |
OK, now it sounds more like cracked solder to the input jack or a bad jack, but either way, PV stands behind their amps with the warranty.
| The Following User Says Thank You to Enzo For This Useful Post: | sully57 (06-25-2009) |
| | #6 |
| Junior Member Join Date: Aug 2009
i have a problem with my peavey vyper 15, i dont know how to get rid of the tap tempo feature
| | #7 |
How to get rid of it?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Peavey VYPYR 15 | Valvehead | Maintenance, Troubleshooting & Repair | 20 | 10-24-2009 01:51 AM |
| Peavey 2000 problem | drewl | Maintenance, Troubleshooting & Repair | 12 | 07-09-2008 06:34 AM |
| Peavey Mace Problem | baddog | Maintenance, Troubleshooting & Repair | 30 | 04-21-2008 04:40 PM |
| Peavey problem | Noah Pearly | Maintenance, Troubleshooting & Repair | 2 | 01-19-2008 06:10 AM |
| Peavey 6505+ problem | Conqueror | Maintenance, Troubleshooting & Repair | 2 | 04-19-2007 01:32 AM |
