Old 06-23-2009, 11:30 PM   #1
Question Ampeg VT120 Acting Funny
Hi all, newb here.
I have had an Ampeg VT120 sitting around for 2 years and not sure what is really wrong w/ it, and don't want to dish out tons of cash for something that can mean just tube replacement, etc. I've read that these amps are awesome, but I just haven't heard the full potential of the am.
It comes on and has normal volume once it's on. After a while (seems once tubes warm up) the volume goes DOWN. If I turn up all the way, I can get okay room volume, but at times it goes back to full volume and LOUD.
Not sure what I would need to do, so I've been using it as a cab for a no name v-4 clone head.
Any suggestions, comments, and what not?
harmonix is offline   Reply With Quote
Old 06-24-2009, 08:15 AM   #2
Hi,
For detailed TS it would be required to measure heater and plate voltages to see if they brown out but usually such symptoms are caused by dirty/corroded input and/or FX send/return jacks. If present jumper the FX loop with a patch cable and check, also giving the input jack a good shower with DeOxit would be first action. All further TS would require to work on the powered amp open so it is a job for a qualified technician...
just my 2c
bluesfreak
bluesfreak is offline   Reply With Quote
Tags
ampeg, broken
Correct Voltage to bias my Ampeg VT120 skot10 Maintenance, Troubleshooting & Repair 7 02-27-2009 07:11 PM
This Is Too Funny ! Amp Kat Tubes (Valves) 14 04-17-2008 11:37 PM
Christmas funny Sock Puppet Lobby 1 04-06-2008 05:15 AM
Bias adj for my Ampeg VT120 Head skot10 Maintenance, Troubleshooting & Repair 1 12-01-2007 05:21 AM
5E8A bass pot is acting funny Bluefinger 5 E 3 2 04-11-2007 10:48 AM
