Go Back   Music Electronics Forum > Amplification > Guitar Amps > Vintage Amps
Old 06-25-2009, 11:03 PM   #1
1981 Fender "blackface" 6 watt champ????
around 81, fender silverface champs reverted back to blackface cosmetics and then were banished for the rest of eternity. ive poked around in there and the circuit seems to be the same as the AA764 on a schematic diagram, but was wondering if the output transformers differ from the silverface champs/princeton's or your opinions on the sound of these last year champs (one watt louder than the blackfaces keep in mind). mine has been retubed with tung sol reissues, outfitted with a weber ceramic blue pup and recapped with an OEM and sprague coupling caps...sounds great with the exception of the cheap particle board enclosure...rattles like crazy!
bbrownsbrick1 is offline   Reply With Quote
Old 06-26-2009, 04:15 PM   #2
Quote:
The silverface Princeton's OT is centertapped, so yours is different from that but should be similar to the silver champ and vibrochamp.
If you are looking for something with a little more heft, an inexpensive option is the Edcor GXSE10-8-8k. They also make a 4 ohm version.
The additional 1 watt is obviously what is making your cabinet rattle
RWood is offline   Reply With Quote
Peavey Delta Blues - No Sound - All Tubes Glow - Powered "On", Made a "Hum", and died Renegade44 Maintenance, Troubleshooting & Repair 15 12-15-2009 05:24 AM
"So Watt" -$225.00 Weber 5E3? thumbs 5 E 3 39 10-29-2009 03:21 AM
SF 1969 Champ, what is causing "chirping" ? Shontsy Maintenance, Troubleshooting & Repair 17 08-20-2008 02:51 AM
"Champ" power tube options and load requirements greg Theory & Design 4 05-13-2008 02:28 AM
Standard Amp "body" and "Limit" controls - what the hell are they? Ptron Theory & Design 7 10-02-2006 06:32 PM
