Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 06-26-2009, 12:40 AM   #1
Selecting Reverb Transformer
Hi all,
I have just finished building a DR103 clone from scratch, using parts I had lying around. All I had to do was buy a capacitor; it cost me 4 british pounds. I could not believe it when I turned it on and it actually worked (and sounded great...)
In a similar mindset, I am going to try building an amp of my own design. I've never done this before, so bear with me!
I have an Accutronics reverb tank, code 8BC1C1B. Decoding this, it has a 190 ohm input impedance, and a 12k ohm output impedance. I want to drive this with a 12ax7. I understand that to do this, I should get a transformer that matches the output impedance of the 12ax7 with the input impedance of the tank.
So I've done some maths (please tell me if it's not correct!):
O/p impedance of 12ax7 is 70k in parallel with plate resistor.
Using a 100k plate resistor: 41k
Impedance Ratio is 41000:190, or about 215:1
To get the turns ratio, take the square root of this = 14.7
240V / 14.7 = 16.3
So if I found a 240V to 16V transformer, I could use this as a reverb driver?
Also, what kind of power should the transformer be able to handle?
Any suggestions are much appreciated!
Thanks,
Harry.
harry is offline   Reply With Quote
Old 06-26-2009, 07:09 AM   #2
I would encourage you to just get a Fender driver and try it! I bet it'll work just fine.
what about this?
I don't know that verb needs a super precise ratio...try some things and see how it works. You could always just buffer the 12ax7 with a mosfet to decrease the driving impedance and drive the tank using a cap.
Fender verb transformers are designed with parallel 12at7's in mind. The reflected impedance from a high impedance coil like that may favor the 12ax7 anyway.
jamie
imaradiostar is offline   Reply With Quote
Old 06-26-2009, 11:07 AM   #3
Hi Jamie,
Thanks for the suggestion... the Fender reverb drivers seem a little bit harder to come by in the UK! If it's just a transformer with a 15000:8 ohm impedance ratio then might be easier and cheaper to find my own.
I'll have a little search and see if I can find someone who stocks one over here.
Old 06-26-2009, 12:53 PM   #4
Firstly, half an ECC83 makes a very poor reverb driver due to its low power, but it can be done. If you can though, I would recommend a more powerful device like an ECC81 or ECC82.
From your description you seem to be describing a parafeed design? i.e., a 100k load resistor,which is cap-coupled to a transformer. You'll get really puny power from an ECC83 in this mode. A conventional transformer-loaded stage is a must.
You'll want a primary impedance from about 40k to 60k (you're reasoning was wrong, but your answer was reasonable). Into 190 ohms, a 240V to 15V or 16V transformer would do. You will only get about 250mW audio power, but because there will be DC current in transformer, a 3VA tranny is probably necessary.
Otherwise you can find really small OTs in old radios and radiograms. A 100V line matching (PA) transformer can also be used and are quite cheap. One with a 2W to 5W tapping into 8 ohms would suit you.
However, you are fortunate in having a medium impedance tank, so you may be able to drive it without a transformer. An SRPP could save you a lot of space and money. See here for more info: The Valve Wizard
Merlinb is offline   Reply With Quote
The Following User Says Thank You to Merlinb For This Useful Post:
harry (07-01-2009)
Selecting a Choke cminor9 Theory & Design 10 06-23-2009 07:22 PM
Selecting OT Primary Impedence from Load Lines kleptocracy Theory & Design 7 04-22-2009 12:38 PM
Selecting a speaker for my Traynor YCV50 SlipDigby Mods & Tweeks 4 04-22-2008 08:21 PM
Help selecting tubes/rect for Princeton project PeaveyBandit Build Your Amp 2 03-17-2008 06:08 PM
Selecting a Primary Impedance Tim Hall Theory & Design 7 06-27-2007 06:50 PM
