| | #1 |
| Junior Member Join Date: Jun 2009
| Fender Blues Deluxe Components Source
I have a '96 Blues Deluxe and am in need of some components. Power switch DPST panel mount Carling Toggle Fender #036570 R85, R86 5w 10% 470 ohm res CR 22,23 1N5353B Zeners CF 1/4W 5% 100K res I would like to be able to order all from one source and am asking if someone can give me a source for these parts. John |
| | #2 |
| Mouser Electronics - Electronic Component Distributor Allied Electronics - Electronic Components Distribution DigiKey Corp. | Electronic Components Distributor | United States Home Page All the parts on your list are generic, so most parts houses could cover it.
| | #3 |
| re:supplier
Thanks for your reply Enzo. I found a place last night called Newark. They were very helpful. For those power resistors, I ended up ordering a couple of Dale aluminum housed 500ohm which I plan to mount to the cassis side and wire in. Do you think 500 is close enough? Power Resistor Power Rating:50W Resistance:500ohm Resistance Tolerance:± 1% Series:RH Operating Temperature Range:-55°C to +250°C Resistor Element Material:Ceramic Temperature Coefficient:± 20ppm |
| | #4 |
Newsong, Dude if those are sand block power resitors,I'll send ya a couple no problem.Those Dale's are not the way to go,, in my opinion anyway..PM me if ya need them.. DW |
| | #5 |
They are the dropping resistors in the power supply circuit and typically get so hot due to the poor design that they are constantly needing maitenance. It is my idea to get them off the board and thereby save the constant resoldering etc. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Fender Blues Deluxe Help | donegone | Maintenance, Troubleshooting & Repair | 4 | 07-06-2009 07:52 PM |
| Fender Blues Deluxe reissue question | bracewell | Theory & Design | 5 | 03-08-2009 06:25 AM |
| Fender Blues Deluxe Reissue | Steve A. | Guitar Amps | 7 | 10-30-2007 07:57 AM |
| Fender Blues Deluxe crackling. | RWoody | Maintenance, Troubleshooting & Repair | 3 | 10-22-2007 06:28 AM |
| Rattle in new Fender Blues Deluxe. | Wiborg | Maintenance, Troubleshooting & Repair | 5 | 08-09-2007 08:08 AM |
