Results 1 to 3 of 3
Thread: 3 screw humbucker back plate
    Sep 2008
    11
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I have a 1980 Gibson Sonex (which I love, by the way... it's sort of like a slab LP with plastic and wood sandwich body). "Resonwood"! "multi-phonic body"! Definitely space-age.
    The Gibson zebra HBs on it have 3 screw mount tabs instead of 2, which allow you to adjust the slant of the pup to match the string angle. On the other hand, they prevent you from turning the HB around, unless you change the plate.
    Can anyone tell me more about these HBs? Did Gibson use them on other guitars of the period or beyond?
    --Paul
    0 Not allowed! Not allowed!
    Tone Mechanic
    Dec 2006
    1,066
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Ibanez also has 3-hole baseplates. 2 holes on one foot and one hole on the other. It drives me crazy because I'm trying to put back to spec 2 80s Ibanez Rocket Roll II Vs that have either the original bridge pickup ring missing or it has an extra hole drilled out in the ring (between the two holes) to fit a normal pickup.
    It is almost impossible to find those vintage Ibanez pickup rings.
    Sep 2008
    11
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    kevinT --
    Don't know if you're looking for repro or only original parts, but I did come across these while researching my own pickups: Ibanez three hole pickup ring, neck position
    --Paul
  1. Humbucker base plate with flat or 1/4" legs
    By maellaguitars in forum Pickup Makers
    Last Post: 08-02-2008, 08:09 PM
  2. Does anyone know...humbucker base plate with flat legs
    By maellaguitars in forum Guitar Tech
    Last Post: 07-27-2008, 06:20 PM
  3. humbucker back screws
    By Possum in forum Pickup Makers
    Last Post: 10-03-2007, 09:01 PM
  4. Humbucker slug or screw coil to "hot" lead...
    By In The Light in forum Pickup Makers
    Last Post: 02-10-2007, 12:09 AM
  5. back plate shielding system
    By scorpio in forum Pickup Makers
    Last Post: 08-18-2006, 04:16 AM
