| | #1 |
| Senior Member Join Date: Jul 2007 Location: leighton buzzard, uk
| How does a Tube Rectifier fail?
Never had an amp with a tube rectifier before, so I don't know how they behave. I'm making an amp with a 5AR4, the power transformer secondary measures 720V ac with a meter (is this commonly labelled 360-0-360?). after rectification it produces 390V. I checked voltages a while ago without tubes and it was giving out 520V. If I monitor the plate of my EL34s as I play, the voltage slowly drops. I imagine the amp would fade out completely eventually. So my question is: when tube rectifiers die, do they fade out slowly? |
| | #2 |
| Junior Member Join Date: May 2009 Location: Pacific Grove
I had one go in a Super Reverb [decades ago, before I knew any of this stuff] and it glowed red and took out some filter caps too. It must've had a short.
| | #3 |
Does that voltage continue to drop? Or does it only drop a certain amount as the amp warms up? And does the voltage climb back up when you stop making sound through it? That would be normal.
| | #4 |
It continued to drop.. maybe a volt every thirty seconds. Today it gave up completely and began arcing. Oh well. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Problem with tube rectifier! | matteodic | Vintage Amps | 11 | 12-28-2009 01:19 PM |
| phase 90 mod fail :o( | overpoweredbyfunk | Guitar Effects | 7 | 03-30-2009 05:38 PM |
| What can cause spring reverb tank to fail? | H Chandler | Maintenance, Troubleshooting & Repair | 8 | 04-24-2008 03:11 PM |
| rectifier tube analysis | henryfordcastro | Maintenance, Troubleshooting & Repair | 2 | 03-20-2008 05:49 AM |
| How can you tell if a rectifier tube is bad? | marshall2555 | Maintenance, Troubleshooting & Repair | 4 | 05-19-2007 12:59 AM |
