Go Back   Music Electronics Forum > Amplification > Other Amps
Old 06-29-2009, 08:53 PM   #1
Peavey XR 1600D powered mixer no output
Fixing to break into this thing. Any heads up on what the problem (or IC) causing this prob would be appreciated.
DM40744 is offline   Reply With Quote
Old 06-30-2009, 02:32 AM   #2
Be more specific. No output to speakers, but output OK to line outs and sends? No out at all anywhere? ANything happen if you feed the power amp in jacks, upper right? How about the main outs, the graphic ins and outs, the monitor outs and headphones? ANy of them work?
Aside from interconections and cutout jacks, you could have: blown power amp, blown internal fuses, missing power supply voltages, bad op amp in some buffer stage, connector off bewteen subassemblies, etc etc.
__________________
Enzo is online now   Reply With Quote
Old 06-30-2009, 06:03 PM   #3
Sorry, Got in a hurry with my post.
No output through the speakers. Main, Monitors,graphs and phones are all ok.
Nothing on the power amp in.
Customer said it made a squeal and died. Was wondering if this was caused by a regular problem with this model.
Old 07-01-2009, 01:55 AM   #4
If the power amp in jacks are not responsive, then the power amps are not running. If there are two dead power amps, that tends to mean to me something they have in common is bad, most likely powr supply.
__________________
Old 08-24-2009, 04:18 PM   #5
I own a XR1600D and happened the same to me once. I could fix it replacing an internal fuse that it was burned out.
lean is offline   Reply With Quote
Peavey MC-16 Mixer powers up, nothing else. MickeyB Music Electronics 7 05-08-2009 02:08 AM
Sunn SX8350 Powered Mixer flon_klar SUNN 3 12-14-2008 04:19 PM
Mirage powered mixer marx Music Electronics 1 08-06-2008 03:08 AM
yamaha emx 660 powered mixer help dtobian Maintenance, Troubleshooting & Repair 20 01-31-2008 06:54 AM
Yamaha Powered Mixer Emx 860st e_c_mccollum Music Electronics 1 04-18-2007 12:02 PM
