Results 1 to 2 of 2
Thread: Fender Super-Sonic Driving Ground
    rf7
    rf7 is offline
    Supporting Member rf7's Avatar
    Sep 2007
    458
    This amp won't turn all the way down on the Burn Channel with the Gains cranked, and you can actually see the signal on the ground itself. What could be causing this?
    http://www.fender.com/support/amp_sc...0(Updated).pdf
    Senior Member Enzo's Avatar
    Lansing, Michigan, USA
    18,042
    If you can scope the signal on the "ground" then your scope is not grounded to that ground, I'd bet. You scope is maybe grounded over in the corner to the chassis or something? Between the ground end of the pot and the chassis , there is resistance. Wherever there is resistance, the potential for potential difference exists - voltage, and that can incl;ude signal. There is enough gain, especially in the dirt channel, in this amp and others for cross talk to skip stages even if controls are zeroed.
  1. fender super sonic
    By gtrboy in forum Guitar Amps
    Last Post: 09-17-2010, 03:57 AM
  2. Fender Super 210 (Did Fender make this junk)
    By ENB in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-05-2009, 12:01 AM
  3. fender super 60
    By setat11 in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-23-2009, 08:13 PM
  4. Fender Super 60
    By drewl in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-22-2008, 10:56 AM
  5. Fender amp reverb's driving me nuts!
    By Analog Assassin in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-10-2006, 11:52 PM
