Results 1 to 14 of 14
Thread: magnet polarity tester ?
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,024
    HI everyone this is first post, just ordered some pickups kits from stewmac my question is should i get a polarity tester or use a compass ,also why can't i just use a small magnet like one of those for picking up nut n bolts on a little telescopic handle, will touching the a alnico polepeice with the magnet change your pickups tone or have any effect on pickup
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,927
    I have one of those Stew-Mac checkers, just because it's handy and I didn't have a compass, but either one will work.
    You shouldn't touch another magnet to your pole pieces, and don't get the Stew-Mac polarity checker too close to alnico magnets either. I hold it a few inches away from the pickup.
    You can also just use a magnet with one side marked, and once again don't touch it to your poles.
    I'd go with the Stew-Mac checker or a compass.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
    http://coneyislandguitars.com
    Supporting Member belwar's Avatar
    Jul 2008
    1,066
    I bought one from mcmaster carr that works well. Also if you end up getting a Gauss Meter it has a polarity tester built right in. Not a must for a pickup builder, but it sure is handy.
    Gaussmeter - GM200A
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    Would Lenz's Law work? Basically just a coil of wire and a volt meter?
    (Second frame down) HyperPhysics
    If velocity is always the same direction, and the meter is always hooked up in the same direction, then you should be able to determine the polarity of the magnet.
    -Mike
    Boston, MA area
    2,578
    Quote Originally Posted by defaced View Post
    Yes, the Lenz's law approach will work. In practice a milliammeter (the modern day descendant of the galvanometer) may be more sensitive than a voltmeter.
    But a compass is simpler.
    The absolute simplest is to put the magnet on a piece of wood or a little boat floating in a bowl of water, and wait for it to orient itself to the Earth's magnetic field. This is how the Chinese built the original magnetic compasses.
    Senior Member -Elepro-'s Avatar
    Apr 2009
    434
    if you use a compass.... ot the little boat ..... remember that Earth's magnetic field has north magnetic pole at south geographic pole....
    bye
  7. #7
    Boston, MA area
    2,578
    Quote Originally Posted by -Elepro- View Post
    if you use a compass.... or the little boat ..... remember that Earth's magnetic field has north magnetic pole at south geographic pole....
    Yes. The "north pole" of a magnet (not including the Earth itself) is the pole that seeks North in the Earth's magnetic field.
  8. #8
    Old Timer Possum's Avatar
    Planet Mongo in the country of PAF
    3,951
    Compasses can sometimes be a bad idea because the needles in them can pretty easily be remagnetized by a strong magnet without you realizing it. I did this with some neo magnets, then realized later the North side of the needle was point South
    http://www.SDpickups.com
    Stephens Design Pickups
  9. #9
    788
    I've got the Schatten polarity tester and don't know how I ever did without it. I hate that nagging feeling that I put the bar magnet in the wrong way. The tester tells me right away just by putting it near the slugs or screws.
    It also reassures me that I didn't glue a rod magnet in upside down...
  10. #10
    Senior Member mkat's Avatar
    /usr/bin
    265
    I use the Stew Mac polarity tester, which I find much handier than a compass.
    int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
    www.ozbassforum.com
  11. #11
    Tone Mechanic
    Dec 2006
    1,066
    Get the SM tester, it is worth it. I use it when assembling the pickup and I also use it to double check the polarity just before packaging them up.
    I would actually buy a couple to keep around.
  12. #12
    Old Timer RedHouse's Avatar
    Jun 2006
    Pacific NW - USA
    1,776
    Quote Originally Posted by Zhangliqun View Post
    Same here. I don't like to mark the magnet with a sharpie as some do, and so I use the StewMac tester during assembly.
    In fact I liked that little tester so much I bought a second one, now I can have one on my bench where it belongs, and take the other with me when I go out to do stuff away from my shop.
  13. #13
    Staten Island, NY
    10,927
    I use the Schatten tester, AND, mark them with a Sharpie! I hate putting the magnet in backwards.
  14. #14
    788
    Quote Originally Posted by RedHouse View Post
    What the hey, they're just $8 or $9. Buy two or more and save on the shipping, which costs as much as one tester from Stewmac.
  1. Getting a Hickok tube tester going again.
    By Ptron in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-09-2009, 08:53 PM
  2. capacitor tester
    By scole in forum Theory & Design
    Last Post: 05-15-2009, 05:24 AM
  3. Op Amp tester
    By Twist in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-04-2009, 06:28 AM
  4. Input impedance tester
    By randomair in forum Music Electronics
    Last Post: 02-09-2009, 07:46 PM
  5. How to use a tube tester
    By MitchK in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2007, 10:38 PM
