| | #1 |
| Member Join Date: Feb 2009 Location: The Detroit area
| How to shim... (there are so many ways...)
This is a how to, I have been working on guitars, and I could use some advice... yes.. I know the concept of shimming, but I am comming here with a CUP EMPTY state of mind ... I want to learn, it doesn;t matter what I know, but what you know... Here are some questions beginners would ask... Why do you shim a guitar? What effects does it have on tone? HOW do you shim a guitar? What material do YOU use (and we all use different things..lol) What guitars specifically (of the vintage sort) need shimming the most.. I though tthis would be a good how to...and a great way to share trade secrets, and to help those new guys learn a bit more... Last edited by EffectsGuru; 07-01-2009 at 06:35 PM. |
| | #2 | |
| Senior Member Join Date: Feb 2007
| Quote:
| | #3 |
| Senior Member Join Date: Jan 2008
As to why a neck sometimes needs to be shimmed, I think this a pretty good explanation. "Some guitars will just NOT adjust properly with the standard methods available like the bridge saddles, nut filing adjustments and the ability to set the bow (or lack thereof) of the neck itself. Adding shims to the bolt on neck may be necessary to get the guitar to play properly at all locations up and down the neck. A nut shim acts as a spacer between the nut and neck raising and lowering the distance between all of the strings at the lower end of the guitar, starting at fret 1 and moving towards the body of the guitar. A neck pocket shim acts as a spacer between the neck and body, changing the angle from which the neck protrudes out away from the body. Try to imagine the strings of your guitar as a flat plane and the fret board as a parallel plane running underneath them. The angle of the top plane which contains the strings is controlled by the position of the bridge and the nut. The angle of the lower plane which is the fret board is controlled by the neck pocket of the body. If your setup is perfect these two planes will have an equal distance between them at any point. If your guitar doesn''t look this way try adjusting the height at the bridge itself first. This will usually take care of the problem unless you find your action becoming too high or to low equally across the length of the fret board. If adjusting the height at the bridge corrects the problem but leaves you with too high or low of an action (distance between the strings and fret board) then you will need to resort to using a shim." |
| | #4 |
Ok, is it ok to shim not to change the angle but just to get the measurement between the 12th fret and the bottom of the low E (the Action) to a lower measurement? For example... the action will not go low enough, and I have set the neck as good as possible and the bridge on the Jazzmaster just won't let me go any lower... so it's clear that it needs one... is it ok to put the shim in between the 4 bolts so it's raised, but at an even level (NOT changing the angle, just raising to a point where the bridge can now be used effectively) also, is a nice hard business card stock ok? the most renouned fella' in my area uses instant lotto tickets, so I assume, that should be fine... just wanted to get everyone else's 2 cents, shimming is fairly new to me, I have only done it a few times, and I have always told the customers that I will readjust for free should it need it after I shim, and if they are not happy I will refund their money, (and restore the guitar to where it was before they brought it to me should that be needed)... that being said I have never had to do that...
| | #5 |
You'll be able to get by with a much slimmer shim if you adjust the neck angle, placing the shim under the part of the neck closer to the bridge. I'd think less added material is better here.
| | #6 | |
| Quote:
| | #7 |
The particular guitar I am referring too, had had fret work done on it (not by me) and with shimming like DAVE KERR described, I tired various thicknesses, but it had issues down in the high fret area due to the angle change, it just didn't have enough clearance, so a ended up slightly lifting it evenly (as in without changing the angle), have you had any problems doing it this way? I have not, but it's not something I normally do... the jazzmaster bridge seems to be a poor design (IMHO). I hear they were shimmed from the factory, I would like to find out specifically what they used back than, just out of curiosity, and how they were placed. Thanks for all the feedback so far... it's been helpful. I want to establish good habits from the start, and do good work on guitars... so it's very important to me to do things correctly/in a manner that is effective.
| | #8 | |
| Quote:
| | #9 | |
| Quote:
| | #10 | |
| Quote:
| The Following User Says Thank You to voodoochild For This Useful Post: | EffectsGuru (07-15-2009) |
| Bookmarks |
| Tags |
| guitar repair, how to shim a guitar |
| Thread Tools | |
| Display Modes | |
| ways to attach eyelet board to chassis? | kbobb | Tweed Builders | 6 | 09-03-2008 06:53 PM |
| ways of making a bobbin | black_labb | Pickup Makers | 21 | 08-19-2007 11:03 PM |
