| | #1 |
| Junior Member Join Date: Jul 2009
I'm not sure if this problem is with my amp or my cabinet. This amp is normally extremely loud. I barely need to take it past half way while jamming. But while I was playing one day it started making a strange crackling noise, Shortly after most of the power this amp had was gone. with both the lead and master volume at full blast it was terribly quiet. it still plays but also crackles horribly, and fades in and out. I hope some one can possibly give me some options as to what is going on with my amp. As I have no idea. thank you. |
| | #2 |
| Senior Member Join Date: Mar 2008 Location: Germany
Welcome to the place. The issue with your amp can be several things. One of the easiest ways of troubleshooting is to change tubes with known good ones. Watch out if you played the amp before, they're hot. If you don't wanna change all of them at once, have a look at them. Does any of them look burned or cracked? If not change 'em one by one. Amp still quiet? |
| | #3 |
| Senior Member Join Date: Dec 2007
First check your speaker cable and cab with an ohm meter to make sure you don't have a short or a bad connection. Then check them with another amp. If the cable and cab sound good, swap out the output tubes. If that doesn't remedy the situation, swap out the preamp tubes. If that doesn't do it you are going to have to troubleshoot and it could be a lot of things as said previously, hopefully not an output transformer.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Marshall Lead 12 Head tube conversion | RogerWilco99 | Conversions | 19 | 09-11-2009 12:12 AM |
| Hiwatt Lead 50R no quiscient current | lowell | Maintenance, Troubleshooting & Repair | 13 | 07-01-2008 06:30 PM |
| Hiwatt Lead 50R cannot remove chassis! | lowell | Maintenance, Troubleshooting & Repair | 0 | 06-27-2008 05:28 PM |
| Hiwatt Lead 50 bias reistor | tonezoneonline | Maintenance, Troubleshooting & Repair | 7 | 04-25-2007 04:08 PM |
| Hiwatt SG50 Lead | tonezoneonline | Maintenance, Troubleshooting & Repair | 0 | 04-18-2007 09:31 PM |
