| | #1 |
| Junior Member Join Date: Feb 2008
| add depth/resonance control to Bugera 6262
Ok guys I bought a Bugera with the intent to mod it. The one I got was the 5150 II clone. What I want is to add the depth/resonance control to the 2 master sections. Should be pretty simple right? Also if any one has a schematic for a 100/50/25 power switch (boogie mark series) I want to add that too. LET THE FRANKENAMP BEGIN!!!!! |
| | #2 |
| Senior Member Join Date: Sep 2006 Location: Newcastle (UK)
check out the 5150 schematic and apply it to your amp - simple.
__________________ HTH - Heavier Than Hell |
| | #3 |
| Or not... I am just understanding schematics. I can barely make my way through an overdrive schematic. I have been modifying pedals and doing my own wiring on guitars for a while. So I'm no slouch in soldering or elec. basics. I have the 5150 II schematic. I just need someone to explain or draw a diagram of how to add the depth controls. Here's the Schematic. ![]() Also if some one could explain how to do the 3 way power switch (100/50/25%). I know one does the pen/triode thing and the other cuts out 2 tubes please help. |
| | #4 |
| Senior Member Join Date: Apr 2008
where are you gonna shoe horn in 4 extra knobs? If you have a spot I'd use the smallest pots I can, maybe concentric knobs and only two spots: 2Meg/1 Meg Dual Pot w/Switch (Pkg of 4)-The Electronic Goldmine ![]() these might work, put a 10k resistor across the 2M section and you've got a dual 1M/ 10k audio pot, the switch could be wired to cut out the FDBK, as some like this sound. I'd get a little PCB from Radio Schack and solder up the components and wire it in! |
| | #5 |
| Senior Member Join Date: Dec 2006 Location: York Pa
I would use the values for the caps and pots in from the 5150II schem and use the JSX as a guide how to hook everything up. I think the JSX schematic is easier to understand because it only has one set of presence/resonance controls, (http://www.schematicheaven.com/newam...jsx20_head.pdf). The controls are in the bottom lower left hand side of the first page, and the phase inverter is on page 8. It's really pretty simple to do, all you're adding is a pot and a cap, but I think the 5150II schem is difficult to see what's happening and what goes where.
__________________ -Mike |
| | #6 | |
| Quote:
I know I'm only adding a couple pots and resistors and that it's really simple. For some reason I can't figure out where to insert them. I'm hoping someone can put together an idiot proof diagram that says cut this and solder it here. I really don't get amp schematics yet. | |
| | #7 |
you first will need a schematic of the Buggy, as it will be needed to find the components that correspond to the 5150II schematic. Or just trace pack the feedback from the 8 ohm speaker output, its usually a shielded wire running to the phase inverter (the last 12ax7 before the power tubes). Find pin #2 on the PI socket and trace it back to the 0.047uF/400v cap and the 4.7k resistor which goes to ground (use a meter with amp off and big PS filter caps bled carefully with a 5k 2W resistor) the feedback wire should connect here (and maybe have its sheild grounded too). Build up the JSX circuit on a little 1x 2 PCB from Radioshack, triple check it and carefully cut the FDBK wire and put it inline. The signal is low voltage but potentially high current, place it carefully away from wires and metal, wrap in saran wrap to be very careful, try knobs. Adding a switch to remove the fdbk is appreciated by some, but may sound bad for a 5150.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Bugera 6262 mod. | Danglin' Fury | Maintenance, Troubleshooting & Repair | 3 | 06-09-2009 07:05 AM |
| Bugera 6262 help!! | mattbreaker | Tubes (Valves) | 17 | 10-07-2008 02:09 AM |
| Locking Nut Depth | Dansk_84 | Guitar Tech | 0 | 09-29-2008 08:56 AM |
| How to add tone control to my VOM Champ? | Regis | Mods & Tweeks | 5 | 06-02-2007 09:42 PM |
| Depth or Resonance mod | Valvehead | Mods & Tweeks | 10 | 03-08-2007 01:08 AM |
