Old 07-02-2009, 10:32 PM   #1
Peavey 400BH blows fuse
I have a 70's Peavey 400BH that blows the fuse after about five or six seconds of being turned on. I can hear it draw down power on a small fan I have plugged into the same outlet. Any Ideas
Bruce
Memphis is offline   Reply With Quote
Old 07-03-2009, 04:23 AM   #2
Have you got a schematic and do you have any basic electronics experience?
Soldering skills, using a multimeter...etc
Twist is offline   Reply With Quote
Old 07-03-2009, 08:13 AM   #3
Answer Twists questions first. I'd be expecting shorted output transistors.
Schematic
__________________
Old 07-06-2009, 11:26 PM   #4
Have schematic
"Have you got a schematic"
Yes.
I have built my share of tube amps.
I checked all the output transistors (by removal) All appear to be good.
Bruce
Old 07-07-2009, 02:33 AM   #5
Isolate the problem.
Disconnect the secondaries from the board - the oprange wires, and the red wires - and power up. Does the transformer running alone like this still pop fuses?
Look up "light bulb limiter." Make one. Use it.
Or use a variac and ammeter.
If the transformer is OK, connect the orange wires. only. Blow or no? Then the red ones.
All outputs "appear" to be good? None measure shorted on a meter?
Check ALL rectifier diodes in the powr supply. ANy shorted?
Make sure CR9, CR13 are not open, and that the connections to CR13 are OK.
__________________
valvestate 8080 blows fuse DAVO Maintenance, Troubleshooting & Repair 0 03-07-2009 12:17 AM
tsl problem-blows fuse-only runs on two tubes wyomingrocks Guitar Amps 7 12-30-2008 06:56 AM
Workingman's 15 or 12?? Blows Fuse brian4991 Maintenance, Troubleshooting & Repair 2 02-21-2008 05:47 PM
Rectifier tube arcing.... fuse blows Garydean Maintenance, Troubleshooting & Repair 21 02-20-2008 04:59 PM
5E3 immediately blows fuse bk121 5 E 3 13 02-16-2008 08:17 PM
