| | #1 |
| measuring inductance with a meat-and-potatoes DMM
Flipping through the catalog for Active Electronics the other day, I noticed that they carry a DMM made by MTP for $70 that includes inductance measurement in its toolbelt of features. ![]() ![]() Are there reasons why I might want to avoid this, or is this a sound purchase until it breaks? |
| | #2 | |
| Senior Member Join Date: Jun 2006
| Quote:
IIRC it's to do with the freq at which the measurement takes place, and someting about the series resistance.
__________________ -Brad (this is where stuff goes that nobody wants to read) ClassicAmplification.com | |
| | #3 |
| Supporting Member Join Date: Jul 2008
Inductance (L) is frequency dependant. I.e. it changes based on the signal that is fed to the item you are measuring. When a device that measures inductance is turned on, it will send a signal at a specific frequency (Hertz) through the pickup and then the inductance at that specific frequency will be reported back. Knowing the inductance at one specific frequency doesnt tell you very much.. You can really only use that number to check consistance between several pickups. My fear with an item like this is that you dont know what frequency the L is being measured at. It could be 20hz, or it could be 200khz. I bought an Extech LCR meter thinking I would learn alot about my pickups. I really havent. It measures at 120hz or 1khz which isnt usefull enough to get any good information.. The human ear can hear frequencies between approx 20hz and 20,000hz (20khz) so this meter covers only a small range of that frequency. Honestly I regret buying the darn thing now. The best device you could get would be one that would give you a bunch of different Inductance readings between 20 and 20000 hz. Then you could plot them on a graph and get some idea of whats going on. I believe you need an occiloscope for that though - Im not an electronics guy so im not sure. I recently bought an Audio Oscilator that can be manually sweeped from 20-20000hz which I use for determining resonance peak, and my next task is to see if I can use it to determine L. b. |
| | #4 |
| Old Timer Join Date: May 2006 Location: Planet Mongo in the country of PAF
On the contrary, the Extech should be in every pickup maker's tool box. Its the only thing that spots coil shorts for instance. Even without a higher test frequency its super useful for my work. A frequency sweep is useful but its not so great for giving digital numbers when tiny changes happen in your pickup design. If you are only testing one type of pickup and nothing else, well it might not be so useful, but for pickup makers who make a wide variety of designs as well as proprietary work, I'd be lost without mine, I use it every day. The more you use it the more you'll be using it over time. My first LCR meter was a DMM was a Meterman that had inductance capabilities, but over time it was frustrating to use because it couldn't be set on either test frequency and would switch from one to the other if it was hitting near 4 henries, so alot of information I got wasn't real accurate. The Extech was like opening a magic door for me. I did alot of experiments just to learn about coils, what different types do compared to other types, what different winds do. I did the frequency sweep thing too, but never found them to be all that useful in the long run, plus how you set up your driver coil etc. is real hard to make perfectly the same each time, so you get confliciting results sometimes. I tried Joe's resonant peak setup but found it horribly unreadable most of the time, it just didn't work very good for hand wound coils, because hand winding tends to have real slow peaks, vs. machine wound, the DMM just wouldn't see these slow peaks very well, so it would look like there was a never ending peak.... If anything I would like an LCR meter with a 10khz test signal, at least the ACR would probably be accurate enough for my purposes. They are pricey though but its on my list of tools coming soon.....
| | #5 |
| That's the approach I'm taking also. It's way more usefull to plot a curve than have a basic two number reading. Then you can actually see what changes, when making changes, rather than just know that it changed and verify that with one or two readings.
| | #6 |
| Senior Member Join Date: Apr 2009
isn't it most simple with white noise and A-B spectrum analyzer?
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ |
| | #7 |
| Senior Member Join Date: Jan 2008
| | #8 | |
| Quote:
and anyone here who led to you believe otherwise should be spanked and send to bed without cookies. An LCR meter is for quality control on a batch of pickups made from the same component stock, nothing more. It will also help you quickly identify defects like winding cut-throughs and shorts to magnet poles even when the DC resistance is only 150 ohms low and still in spec. -drh | |
| | #9 |
| you can with a pc.... try this ..... (last version doesn't work well with my pc...)
| | #11 |
| Supporting Member Join Date: Sep 2007
| Inductance (L), Capacitance (C), and resistance (R) are three concepts that describe the behavior of circuits that can be represented by lumped elements. L does not vary with frequency. However, any real "component" needs to be described by all three concepts. Some useful real components can be described predominantly by one of the three over some frequency range. Guitar pickups are complicated little beasts. At low frequencies they can be described very well by an inductance in series with a resistance. A good L meter measures both (the low frequency measurement). At higher frequencies, pickups have a complicated impedance. An L meter gives you some information at the higher frequencies, but not really enough to tell you everything about the components necessary to describe a pickup. |
| | #12 |
| Senior Member Join Date: Apr 2008 Location: PDX
| | #13 |
| Senior Member Join Date: Feb 2007
Excuse me for my ignorance but it seems to me that once you understand how everything works together (materials, tension, TPL, etc) you can wind pickups until they sound like you want them to. In regards to testing them why not just read it on a meter for resistance and check the output with a tuning fork. The whole meter with inductance etc, opened a can of worms for me and I ended up ditching it. If you have a short in the coil it won't have enough output or it will read totally off on the resistance. All can be done with a $2 tuning fork and a $20 multimeter IMO. On the other hand I could totally see the use of an inductance meter if you were trying to copy another pickup, active pickups, or rewinding. None of which I do so it pretty much deems itself useless for me.
| | #14 | |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
| Quote:
| | #15 |
| Junior Member |
Certainly off topic here, but I visited your site. I hope not being presumptuous but where do you het your SGD covers made ?
| | #16 | |
| Quote:
| | #17 |
| coil shorts...
Wrong. I have had pickups with coil shorts, or overheated solder joints holding the cable on, they read the right DCR and output was normal. Who checks output anyway if you're shipping boxes of pickups? The ONLY thing that would show a coil short was the LCR meter. The pickup sounded darker than it should have. I don't listen to pickups before they go out, you can't really tell much unless you actually solder them into a real guitar and play it. I discovered the ability of the LCR meter to spot shorts in humbuckers when doing prototype testing. I had a bridge pickup that was sounding nice, good output, but suddenly it was darker than usual, the LCR meter didn't show alot of change in inductance but the ACR had nearly doubled! It wasn't even a coil short, the lead cable had been soldered too many time and the insulation on the inner wire was breaking down (cloth covered stuff). There was NO difference in DCR or anything else, but ACR caught it. I put a new cable on and problem was solved. The same thing for an actual coil short, nothing else will catch it. An LCR meter is a tool and you have to learn how to use it to appreciate it. As I mentioned my first meter that could read inductance wasn't all that useful and was a really limited tool. the Extech is a great tool to learn and use, you'll notice in photos of Bill Lawrence in his ads guess what tool he is using to check his pickup? I keep waiting for one of you guys to buy a meter with 10khz test signal to see how useful they are and what a good brand is |
| | #18 | |
| Quote:
| | #19 |
No problem, I'm making pickups full time now and have always been somewhat of a technical guy, wanting to understand coils as much as I can with my poor mathematical abilities, so the meter helps. Here's one I've been looking at on Ebay, yeah its Chinese but that doesn't necesserily mean they are bad, maybe: LCR RCL LC meter TH2821A inductance capacitance, 10kHz - eBay (item 320361219247 end time Jul-16-09 04:35:58 PDT) |
| | #20 | |
| Senior Member Join Date: May 2006 Location: Cornelius, Oregon
| Quote:
Greg | |
| | #21 | |
| Senior Member Join Date: May 2006 Location: Boston, MA area
| Quote:
| | #22 |
| The primary effect of eddy currents in pickup cores is resistive; that is, it increases the loss. As we have discussed, pickup cores act as a loosely coupled secondary, and a good model is an inductor (the so-called leakage inductance) in series with a resistor aross the main pickup inductance. This is a pretty simple model, and it works OK.
| | #23 | |
| Senior Member Join Date: Oct 2008 Location: Victoria, BC Canada
| Quote:
| | #24 | |
| Quote:
Audio Xplorer (AudioXplorer - Sound analyzer for Mac OS X) does realtime only (?) Inspector XL, from RNDigital, previously Elemental Audio Systems Macintosh Music Software: Oscilloscopes (Shareware Music Machine) Software MacCRO X 0.1.3 Pre1 Mac Audio Function Generator Software Macintosh Scope - Oscilloscope Software (Macintosh and Windows) - Research - ADInstruments | |
| | #25 | |
| Quote:
You can demonstrate this effect with an air coil, a piece of metal, and an Extech. The inductance of the coil does change when the piece of metal is brought near. So does the AC resistance. | |
| | #26 | |
In the case of a very low loss system, I would believe the Extech reading. With significant losses, no. There is both loss due to the series resistance of the coil and parallel loss due to the mutual impedance effects. You cannot model both correctly with a single amplitude and phase reading. Your main point above was the frequency dependence of the inductance. One of the simplest case one can think of is a lossless, poorly coupled transformer with a shorted secondary. A leakage inductance appears in parallel with the primary inductance, resulting in a lower overall inductance, but it is not frequency dependent. Quote:
| | #27 | ||
| Quote:
Many years ago we were looking for a meter that would work with pickups. Most handheld LCR or DMM meters expect fairly pure inductors, and only the instruments costing thousands worked. I forget who discovered the Extech, but the specs looked good so I bought one, and verified it against a maxwell wein impedance bridge: Joe Gwinn's website homepage. So far, only the Extech and perhaps one other $200 handheld (made by the same outfit in Taiwan) work on pickups. Quote:
| | #28 |
Hi, while I don't work with pickups I thought the read here was fascinating. First time I read that L changed with f I thought "oh no, he mixed it up". When Joe Gwinn explained it made perfect sense. So in theory it does not, but in practice L does change with frequency due to imperfections in the core(saturation, which reduces the magnetic capacity of the core), which is news to me. For my work with output transformers and chokes, what induction meter would you guys recommend? I'd like to measure 50/60 hz chokes, 50/60hz transformers, OT's from 20hz to 20khz. I've owned a cheap DMM before that had L measurement but I blew it up and am now looking for a replacement. Any pointers greatly appreciated. Thanks. |
| | #29 | |
| Quote:
A pickup, in particular a humbucker with steel cores, has both series and parallel loss. A measurement of complex impedance gives an amplitude and phase. Given that the loss is series, one can determine both the inductance and the resistance. Same for parallel. But not if you have both (unless they are both small, and so do not matter). If you have both you can measure at a sequence of frequencies and construct a model that matches the measurements. Two might do it in certain cases, but not in general, especially if you have no control over the two frequencies. If you disagree with this please show me how to get simultaneous series and parallel loss with the Extech. Maybe I am missing something. What measurement do you want me to make? | |
| | #30 | |
| Quote:
Extech Instruments: Specialty Meters: Specialty Meters: 380193 The next step up in capability costs thousands. | |
| | #31 | ||
| Quote:
1. I agree that in practical inductors, there can be both series and parallel resistance components, due to different physical effects, and that a two-frequency measurement of complex impedance cannot tease these apart except in unusual circumstances. However, in practical inductors, the parallel resistance is usually very large, and may be ignored, and the parallel capacitance (the self-capacitance) has no significant effect at 1000 Hz, given that self resonance is around 10 KHz. One measures self-capacitance most accurately by finding the self-resonant frequency with various external capacitors, and solves for the extra capacitance needed to make it all work out. (This method is very old, and I first saw it in Terman.) 2. Bringing a mass of non-magnetic electrical conductor, like brass, copper, or aluminum, near to a coil will reduce its inductance due to eddy currents counteracting coil currents. A magnetic conductor such as steel will have permeability increase and eddy decrease in opposition, and things quickly become complex. Laminating the iron greatly reduces the eddy currents, causing the permeability effect to predominate, up to some frequency determined by the thickness of the laminations. For a datapoint, variable-inductance RF coils can be ordered with a variety of core materials, including ferrite, powdered iron, or nonferrous (brass or aluminum). The ferrous cores increase the inductance, while the non-ferrous cores decrease the inductance. Aside from eddy currents, the inherent permeability of most core materials varies with frequency, sometimes in complex ways. 3. Because eddy currents vary with frequency, so will the inductance of a coil with nearby metal, even if the geometry of coil and metal does not change. Quote:
| The Following User Says Thank You to Joe Gwinn For This Useful Post: | kevinT (07-17-2009) |
| | #32 | |
| Quote:
| | #33 | ||||
| Quote:
Quote:
Quote:
Quote:
I do not own an Extech, but it does seem like a useful tool. It would be interesting to compare its measurements with the system I have. | ||||
| | #34 | ||
| Quote:
Quote:
| | #35 | |
For a humbucker coil, these effects are large, not small. That is why I have taken the trouble to put together a system that collects enough information so that one can model them. The evidence is in the earlier thread. Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Measuring inductance with standard multimeter | Yves | Pickup Makers | 29 | 07-10-2008 03:07 PM |
| diode test function on dmm | Alex R | Maintenance, Troubleshooting & Repair | 8 | 07-28-2007 02:03 AM |
| How to check a DMM? | slidincharlie (Carlo P) | Maintenance, Troubleshooting & Repair | 3 | 03-25-2007 10:04 PM |
| Inductance | Paulkstadden | Pickup Makers | 7 | 02-26-2007 05:49 PM |
| Inductance vs Ac Resistance? | jimi | Pickup Makers | 15 | 09-16-2006 02:45 PM |
