Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 07-04-2009, 11:07 AM   #1
Capacitor help (sawtooth signal)
Hi guys, I am using a PIC Micro to generate a signal of 11hz per second (i.e. it pulses 0 and 1 eleven times per second), which will generate a squarewave signal.
I want to modify the signal to output a 'sawtooth' signal. How do I calculate the capacitor value to use?
Is there a formula to use where I input Voltage, frequency etc.
Thanks
__________________
danielclark is offline   Reply With Quote
Old 07-04-2009, 11:28 AM   #2
Supporting Member
Steve Conner's Avatar
If you want to convert a square wave to a sawtooth, you need more than just a capacitor, you need an integrator with a reset switch.
Go and look at the schematics for a Roland JX-3P or whatever, these have square wave oscillators that are converted to sawtooth by an analog circuit.
If a somewhat misshapen sawtooth is acceptable, you can use a RC network with a diode across the resistor to sharpen the falling edge of what would otherwise be a misshapen triangle wave, and adjust the duty cycle of your PIC output to suit. The time constant R*C should be about 5-10 times longer than the period of your wave.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Next to no signal in my old phase 90 lee crosson Guitar Effects 1 01-24-2009 04:29 AM
too much preamp signal?? EETStudent Theory & Design 3 06-26-2008 05:14 AM
Signal Leaking GainFreak Theory & Design 5 03-05-2008 03:49 PM
Signal Path wardevans Music Electronics 1 03-01-2007 05:14 AM
signal on b+??? 12afael Maintenance, Troubleshooting & Repair 6 08-03-2006 05:44 PM
