| | #1 |
| Senior Member Join Date: Jun 2009 Location: Nashville, TN
| Help With Power Supply
Let's preface this with: I don't know much about electricity. I can rewire most any guitar, follow most any wiring diagram, etc... but I don't fully understand electricity. That said, I am in the process of building my pickup winder. I got a bathroom fan motor (since I can plug it directly into the wall), Cub 5 with the add on power supply (so I can also plug this directly into the wall) and the IR optical switch. My problem is that the optical switch is 1.8V and I don't know how to run power to it. I dont want a power cord for the motor and counter AND a wall wart to power the switch. So I need to either build a 1.8V PSU and wire it into the A/C line that will support the motor and counter or hope that maybe the counter can power the switch. Any ideas would be greatly appreciated. |
| | #2 | |
| Old Timer Join Date: May 2006 Location: Boston, MA area
| Quote:
| | #3 |
I'll try that to get up and running, but I really want to have it all powered with one cord to the wall. On a side note, what part of Boston are you in? All the Guitar Center guitar techs in MA and NH work for me. I live close to the MA/NH border in North Andover. You mind if I pick your brains sometime since you are local? |
| | #4 |
| Supporting Member Join Date: Jul 2008
Many of the counters will power thier own sensors. I bought a PAXLCR meter from Red Lion and a Thru-Bore encoder. The PAXLCR powered the encoder through the wires. Red Lion is EXTREMELY helpful. I was a total nub. I called and asked about wiring questions and they guided me through the whole thing. Phone them and tell them that you are thinking about buying a CUB5 (Even though you already have) and that you have a 1.8v optical sensor.. Ask them what you will need to make it work with the CUB5. My guess is nothing and that the unit will power it.. Though a quick glance through the manual shows that the output seems to be 4 - 28 vdc. Also ask them what wires go where. Super cool people and I would buy from them again just based on thier customer support. b. |
| | #5 | |
| Senior Member Join Date: Apr 2007 Location: Guelph, Ontario
| Quote:
Which optional power supply did you get? The 12VDC or 24? It doesn't really matter as you can build a voltage divider for either with a resistor network. A voltage divider does literally what it says. It divides a single voltage into other voltages. For instance, if your power supply puts out 12vdc (volts direct current) and you put it into two identical resistors in series, then between the resistors the voltage will be 6 volts. If there were three in series, then the first junction would be 8 volts, then the second junction would be 4 volts. BUT, if you put the 12vdc into a 5K resistor then a 1K resistor, the voltage between them would be 2vdc. It basically uses 5/6ths of the voltage across the 5k resistor. 2vdc is probably within spec of the optical switch.
__________________ www.chevalierpickups.com | |
| | #6 |
| Senior Member Join Date: Jun 2006
While this isn't your sensor, this diagram illustrates how to interface a sensor with a CUB counter: http://classicamplification.net/winder/OPTEK-CUB4.pdf |
| | #7 |
I have read every bit of your website. It is what made me decide to build a pickup winder. I found it a while before I found these forums. Lots of the pages are broken, but some of them you can correct the url to get working.
| | #8 |
| Can you PM me and tell which pages you see as broken? I moved the stuff a while back off ISP.com over onto a hosted site with GoDaddy.
| | #9 | |
| Senior Member Join Date: Apr 2009
| Quote:
but what is the model of the ir switch?
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ Last edited by -Elepro-; 07-14-2009 at 02:41 PM. | |
| | #10 |
| | #11 |
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ |
| | #12 |
connect: black & green to PWR COMMON white to INPUT A red to +9-28VDC cub5 inpout voltage trough a resitor (needs voltage value PSU for resistor value)
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ Last edited by -Elepro-; 07-15-2009 at 07:58 AM. |
| | #13 |
| But any solid state device should only draw micro amps as current and shouldn't effect the voltage drop across the resistors. This is the IR supply, not the switched voltage.
| | #14 | |
| the IR emitter consumption is 20mA = 20000 uA.... there are no led (IR emitter) that turn on with micro amps Quote:
if you search you never will see a voltage divider for supply a led (the ir emitter) but always a single resistor....
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ Last edited by -Elepro-; 07-14-2009 at 11:26 PM. | |
| | #15 |
| Really? then you sure can use my pdf as a guide to hook your's up. Look at the picture in the middle of the page, you will see how. Right above the part that says "78Lxx" you will see a small chart, you get to pick which 78Lxx device you want to use. Here's how, if you have (or want to use) a 78L09 which is a 9V regulator, you can see on the chart that your resistor values will be: R1 will be 385 Ohms R2 will be 15K These values will give you the correct LED and Ic currents for the Optec. The final piece you need is just to power the circuit with a wall-wart which puts out a DC voltage of at least 3 volts more than the 78Lxx device you decided to use. (ie; get a 12VDC wall wart) |
| | #16 |
| Last edited by automan; 07-15-2009 at 02:11 AM. Reason: added the link to the actual PSU |
| | #17 | |
| Quote:
| | #18 | |
| Quote:
the dip switch 1 on cub5 must be in logic position the dip switch 2 in sink positi (note that when dip-switch 2 is in SINK position inputA of cub5 already has a pull-up resistor then the R2 in Redhouse pdf doesn't need)
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ Last edited by -Elepro-; 07-15-2009 at 08:58 AM. | |
| | #19 | |
| Quote:
| | #20 | |
| Quote:
| | #21 | |
| Quote:
bye
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ | |
| | #22 |
| Mine works, Fairchild H21LOB. I don't have any pics of the resistor board handy, but it's a mess I know that. Next iteration will use either same sensor, or Honeywell SS49E hall sensor. Being fed into Labjack U3HV, software written in Labview 8.5 developer. 90VDC Leeson motor driven by Minarik Motor controller, reversed through Grayhill H-Bridge relay board ( all in turn driven by Labjack). Of course, I have to use an op-amp for the speed control because the labjack only puts out 20ma (20000ua because we apparently have to convert now). Linear stepper driven by labjack as well through stepper controller. All software controlled with infinitely variable traverse rates and wind speeds up to about 1750 rpm. No limit switches, will use an initial rig point and then wind count multiplied/divided by traverse speed. Should be a cool project if I'm smart enough to plug it into the wall that is....
__________________ www.chevalierpickups.com Last edited by chevalij; 07-17-2009 at 01:14 AM. |
| | #23 | |
| Quote:
__________________ .......my gaussmeter project..... schematic & pcb ........ .......first pickup with my cnc winder........ Last edited by -Elepro-; 07-17-2009 at 07:45 AM. | |
| | #24 |
| Junior Member Join Date: Dec 2009
I read all this pretty quick so I may have missed some important details but if you have 12vdc and the unit needs 1.8v and pulls 20ma then a series resistor should be enough. 10.2/.02=501, stock values are 470 and 510. I squared R is like .2 so a quarter watt should do. It is just like a diode right? |
| | #25 | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Power supply connundrum. | octal | Theory & Design | 14 | 04-24-2009 03:07 PM |
| power supply caps | rymac | Maintenance, Troubleshooting & Repair | 1 | 10-07-2008 02:28 AM |
| help with 9v power supply | nopainkiller | Music Electronics | 2 | 09-05-2008 08:57 PM |
| power supply failure? | EETStudent | Maintenance, Troubleshooting & Repair | 5 | 01-15-2008 07:16 PM |
| power supply sag | EETStudent | Maintenance, Troubleshooting & Repair | 3 | 01-13-2008 10:07 PM |
