Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 07-06-2009, 11:15 PM   #1
Schematic needed for Korg DTR-1000 Tuner
Hi All,
A customer brought in a number of items suffering from a nearby lightning strike - one item in the bunch is a Korg DTR-1000 Tuner. I've tracked down the problem to the input board (I can feed a signal directly into the front panel board and the tuner works OK). Korg uses some sort of a conformal coating or something similar on their boards, and I cannot make out any identifying markings on a number of the SMT semiconductors on the input board. I also cannot afford to put much time into figuring out what is on this board, as the repair price will get way out of hand fast. There's not a whole lot of components on the input board, so if I had a schematic, it should be a quick fix.
Tried Korg, but my shop is not an authorized service center, so they will not even give me a part number for a service manual or schematic so I could order through CE Distribution. Can anyone help me out with either a schematic or a suggestion of who/where to look for one? No luck on Google so far.
Thanks in advance for any help,
Rick
W3KQ is offline   Reply With Quote
Old 07-07-2009, 12:33 AM   #2
Here you go
__________________
Old 07-07-2009, 12:47 AM   #3
Thank you!
Enzo, Thanks so much for helping me out! Not that I can imagine having a manual or schematic you don't already have, but I hope I can return the favor someday!!
Thanks again, Rick
Old 07-07-2009, 04:29 AM   #4
Well, so far I do not have the documentation on the HP 5710A Gas Chromatograph (Turbocharged floor model.) The model used by FBI Special Automotive Instructor George Wilbur.
__________________
Yamaha EMX660 Schematic needed bnwitt Other Amps 18 02-23-2010 06:30 AM
Help Needed with an Oberheim Matrix 1000 helpneeded Music Electronics 5 04-28-2009 08:35 AM
aa1164 schematic needed scole Theory & Design 4 07-28-2008 07:37 PM
6BQ6 schematic needed slideman82 Tubes (Valves) 0 10-09-2007 06:08 PM
Jordan Two/04 schematic needed tim Maintenance, Troubleshooting & Repair 8 10-31-2006 03:24 AM
