| | #1 |
| Junior Member Join Date: Jul 2009
| Peavey M100 Help!!
Have a Peavey messenger m100 portable powered mixer pa system Everthing works input cd, mics, headphones, line out BUT...... Both Main L and R speaker ouputs do NOT work..... Bad power amp?? Speaker output relays?? Fuses?? How could I fix or Test....? Please Help....! |
| | #2 |
| Senior Member Join Date: Jun 2008
check the speakers first.
| | #3 |
The power amp is class D, and one chip handles both channels. Are all the connectors on the power map board on fully? The power amp runs on +25/-25VDC - are BOTH present at CN100? Between the chip and Q101 transistor is a zener diode DZ101. is there about 5 or 6 volts across it?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
