Results 1 to 22 of 22
Thread: Dumble clone transformers
    Jul 2009
    11
    Question Dumble clone transformers
    I need a good suggestion for a transformer to replace the one missing from a Dumble Overdrive Special "clone" that I inherited. Does anyone have any idea what transformer these things used? I hope to find one here in the US but no one seems willing to help when I email the manufacturers of similar amps. They act like it's a huge secret. HELP!!!
    Supporting Member Dave Curtis, dB AudioTech's Avatar
    Jun 2007
    USA
    401
    Power or output tranny? What are the amp specs? There are a few different ODS models...
    Senior Member mac1amps's Avatar
    Sep 2006
    Chicago
    172
    FWIW, I recall a client of mine bringing me a Dumble that had a very "Fenderesque" design (2x6L6's in a Class AB configuration), and the transformers used in this amp (power AND output) were actual Fender issue transformers, whereas the name Fender had been stamped on the casing. I'm certain that a properly matched Hammond (or certainly a Mercury Mag.) would be "up to par" for one of Mr. Dumble's units.
    Jul 2009
    11
    Dumble transformer
    Ok. I have a suitable output transformer from a Fender Super. What I need is a power transformer. The amp is actually a Ceriatone Overtone HRM. I think it needs a 6-0 tap.
    Jun 2007
    USA
    401
    Okay, the HRM uses 4 6L6s, right? The Super uses 2, IIRC. Your OP tranny is not exactly suitable (at all). You'd be looking for trannies for a Twin Reverb or Showman; one of the 100 watt amps. I've heard that Dumble used Fender trannies, and the circuit is fairly Fender-based.
    Jul 2009
    11
    Hrm
    The HRM is 2 6L6 40 odd watts. Yes it is fender based.
  7. #7
    Jun 2007
    USA
    401
    Quote Originally Posted by Deafcat View Post
    They have a 100 watt version, too. I wasn't sure which one you had.
    The Super OPT you have should work OK. You'll need to find a PT that fits with the tube compliment you have.
  8. #8
    Jul 2009
    11
    The HRM runs 2 6l6 output tubes and three 12AX7s. There is a pair of relay coils in it that operate the overdrive and preamp boost switching. This means there must be a tap to power the switching as well a the 6.3v heater tap. It looks to me (judging from the schematic) that it is fender based.
    Here are some notes on a Dumble clone from Schematics heaven. This schem looks similar to the HRM to me but it says the one in schematic heaven ran 4EL34 tubes.
    Here's a description of the power supply:
    690 vac from transformer
    I think it is full wave rectified with 103Z disc capacitors across the 4 diodes(also oneacross the standby switch).
    1st stage: series 200ufd@300v each paralleled with a 470k res - 465volts
    2nd stage: series choke
    3rd stage: series 47mfd@350v each paralleled with a 470k - 458 volts
    4th stage: series wirewound 2980ohm resistor
    5th stage: series 47ufd@250v with 470k - 433 volts
    6th stage: series 12k resistor carbon film?
    7th stage: series 47ufd@250v with 470k - 361 volts
    8th stage: series 10k resistor metal film
    9th stage: series 47ufd@250v with 470k - 323 volts
  9. #9
    Jul 2009
    11
    Some more details
    Here are a couple links for the 97 Dumble listed in Schematics Heaven.
    Block diagram showing the relays:
    http://www.schematicheaven.com/dumbleamps/dblock.pdf
    Full schematic (the section of notes I posted are from a "clone" someone built that he states runs "4 EL34" tubes. This only shows 2. It also shows no power for any switching.)
    http://www.schematicheaven.com/dumbl...7fullschem.pdf
  10. #10
    Jun 2007
    USA
    401
    Here's your layout: http://www.ceriatone.com/images/layo...ut/HRM-50W.jpg
    The 2nd schem you posted was drawn by Steve Ahola; I thought I'd seen it somewhere...
  11. #11
    Jul 2009
    11
    Thanks
    Thanks I printed it last night. Looks good. I think I'm just going to get the transformer set listed on Ceriatone's site. Shipping is outrageous but I haven't found anything in the US nor have I found anyone with any suggestions. The Mercury Magnetics stuff costs more for the output transformer alone than the set of them from Ceriatone.
  12. #12
    Mar 2008
    Cincinnati
    238
    Did you check with Brown Note? They sell a 2x 6L6 Dumblesque amp and kits (their "D'Lite 44"), and they sell parts. No transformers listed on their site right now, but you can always ask...
    MPM
  13. #13
    Jun 2007
    USA
    401
    You could use the Super OPT that you have, but IIRC, it's 4 ohm only. You could get a Pro Sonic OPT with 4-8-16, which is what I put in my '76 Pro Reverb. Call these guys and find out about a tranny set for a Pro Sonic:
    Parts is Parts
    Or any other Fender dealer/service center.
  14. #14
    Jul 2009
    11
    Power tranny info
    Thanks for the help guys!
    I did learn that a couple guys who have tried building Dumble clones (whether this is true or not), have had noise problems using the heater tap from a Fender Super tranny to power the switching relay in the D circuit. I can see where this may be a problem, but if your amp is well thought out and your build and grounding scheme is good it shouldn't be a problem, right? Since the one I have is already put together I can't be positive, but the builder was meticulous. The leads aer all perfecly laid out and "bent" at angles instead of just laying "naturally" in the chassis. Maybe there's a reason for this. Maybe he was just anal. Haha. Either way it looks beautiful.
  15. #15
    Senior Member tedmich's Avatar
    Apr 2008
    PDX
    1,220
    FYI Edcor has some excellent transformers for the money, much better quality and value than typical guitar amp steel IME.
    They have 114 PTs available and their EB site makes it a little hard to find the right one... I have an excel file available
    For the Ceriatone HRM as an example, the XPWR029 is an 11lb monster for ~$84 (700V(350-0-350)@400mA, 50V@500mA & 6.3V(3.15-0-3.15)@7.5A)
    Their OT are excellent values too.
  16. #16
    Jul 2009
    11
    Man that's great! Thank you so much! I'll have to check it out. Hopefully the shipping isn"t as high as shipping from ceriatone in Malaysia. Shipping from there is almost as much as the Edcor tranny!
  17. #17
    31
    For an amp like that you can also use the heyboer stuff that mojotone sells. Just get a 50W PT for a Superreverb. That one covers all the needs.
    BTW, perfectly bent wires does NOT sound like the way to do it for the Dumble method. Might work just fine though.
    Good luck!
    Jelle
    Welagen Musical Sound
  18. #18
    Jun 2007
    USA
    401
    "For the Ceriatone HRM as an example, the XPWR029 is an 11lb monster for ~$84 (700V(350-0-350)@400mA, 50V@500mA & 6.3V(3.15-0-3.15)@7.5A)"
    400mA? He has the 50watt, not the 100watt.
  19. #19
    Jul 2009
    11
    Thanks
    Quote Originally Posted by Jelle View Post
    Good luck!
    Jelle
    That is a nice thought. Ceriatone HRMs don't work that way. They use a seperate 6v tap on the transformer to run the switching relays. I did manage to find the actual builder and get some info on the one I have.
    as for the wiring,,, the perfectly bent wires, I will agree, are not the way to go. It was the builder's attempt to quiet the amp down from the noise introduced from running the switching section off of the heater tap. It was an unsuccessful attempt I might add. That's why the project was left without transformers. They went back home to the 5F4 Super they came from.
    Thanks though for the input. I just went ahead and ordered the trannys from ceriatone.
    Dennis
  20. #20
    Jul 2009
    11
    You caught that too,,, I looked at the Edcor site and didn't find anything useable except a seperate 6 v tranny I could've used for the relays.
  21. #21
    Apr 2008
    PDX
    1,220
    IME bigger is better unless you are carrying it... He could use the XPWR109
    700V(350-0-350)@175mA & 6.3V@4A $50.47
    but would need to pull the 60v off the B+ tap
  22. #22
    31
    Well, you could have used the 5V heater tap for the rectifier tube to power the relays.
    Check my website.
    www.welagenamps.com
    I know the ODS inside out.
    Good luck with the amp. :-)
    jelle
  1. Dumble anyone?
    By tubetonez in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-11-2009, 07:03 AM
  2. Dumble thoughts
    By lowell in forum Theory & Design
    Last Post: 06-23-2008, 07:26 PM
  3. Dumble like Mod for Fender Deluxe Reverb
    By Mary Pardise in forum Mods & Tweeks
    Last Post: 04-09-2008, 09:01 PM
  4. dumble feeddback ?
    By Marc in forum Harp Amps
    Last Post: 10-29-2007, 03:45 PM
  5. Rocket Clone
    By ORocket in forum Theory & Design
    Last Post: 04-23-2007, 12:58 AM
