Since both tubes are redplating, that is telling me that your bias supply is opening up somewhere, and not providing the negative voltage to the power tube grids to throttle them back. Look for a cold solder joint, bad (swollen) filter cap or maybe a bad bias pot. Anything that opens up in that negative power (bias) supply would do it. Should be easy to troubleshoot.
LinkBack URL
About LinkBacks
