| | #1 |
| Junior Member Join Date: Jul 2009 Location: Benalmadena Spain
| 5F2-A bad harmonic and distortion
Greetings to everyone, this is my first post and my first build. Iīm an American living in Spain. I have built a 5F2-A using Steve Milbergerīs schematic and layout. I made an error when I wired up the PT basically applying 220v to a 110 wired circuit. PT died on the spot. I obtained a new one and wired it correctly and the amp now amplifies but there is unpleasant distortion and a weird sci-fi sounding out-of-tune harmony accompanying the notes. I fear I have damaged some components with excessive voltage. Can anyone advise me on how to proceed?
| | #2 |
| Old Timer Join Date: May 2007 Location: pacific north west
Wow... With that set up, it could be a lot of things. I'll bet there's a mistake in the wiring. But it could also be bad filter caps. If the high voltage damaged your filters you would have a second oscillating note riding on top of the basic tone. You would also have excessive hum. Chuck |
| | #3 |
Could have blown the OT too, pull the power tube and measure ohms from 6V6 pin 3 to hot terminal of first filter cap after the rectifier.
| | #4 |
| pin three ohms
Thanks for your reply. Pin three to the first filter cap reads 220 ohms. I donīt know how to test the caps but I have ordered new tubes and caps.
| | #5 |
220ohms seems about ball park, OT should be OK.
| | #6 |
| Next step
So my plan from here is double check all wiring, swap out tubes, and replace filter caps. Any other suggestions?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Dropped C tuning open C note with annoying harmonic/ring. Please help! | ultrablue87 | Guitar Tech | 3 | 07-23-2009 02:21 PM |
| Harmonic Tube(s) with attenuator | ENB | Maintenance, Troubleshooting & Repair | 3 | 04-15-2009 06:31 PM |
| Harmonic Vibrato | The Radium King | Theory & Design | 9 | 01-04-2009 08:31 AM |
| Fender harmonic vibrato sound clip? | GibsonLover | Guitar Effects | 2 | 11-10-2008 05:45 PM |
| Harmonic complexity | daz | Theory & Design | 6 | 06-06-2008 09:33 AM |
