Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 07-14-2009, 12:43 PM   #1
Vibro Champ build question.
Can a Stock MM OT handle a 6L6 and a GZ34/5AR4? I'm not looking for more power just a tone change. So I was thinking about changing the bias, adding a 6L6 and 5AR4. Is the OT safe?
StratTone is offline   Reply With Quote
Old 11-08-2009, 03:56 AM   #2
booj's Avatar
A 6L6 draws .9 amps filament current compared ot the 6V6's .45 amps. Since the two 12AX7's draw .3 amps apiece, you'd be going from .3 +.3 + .45 or 1.05 amp draw to 1.5 amp draw for the filaments. That's almost a 50% increase.
Without knowing what the actual spec is on the tranny, I'd say try it and see if it gets too hot to touch for 5 seconds after an hour or two. If it does it won't work reliably.
Also, the GZ34 will probably deliver more voltage to the output tube, as well as the tube itself drawing more current from the supply.
ALSO, the cathode cap fo the power tube will have to be increased to 800 ohms? 1k? to supply proper bias to the tube.
booj is offline   Reply With Quote
Old 11-08-2009, 05:13 PM   #3
guitician's Avatar
Since your B+ is still the same, it may go up a little, your probably OK with your OT.
guitician is offline   Reply With Quote
SF Vibro Champ fuzz rokplo Maintenance, Troubleshooting & Repair 21 12-18-2008 09:16 PM
BF Vibro Champ mod tele-tubby Mods & Tweeks 8 08-29-2008 12:33 PM
Vibro-Champ Help Rick1114 Maintenance, Troubleshooting & Repair 16 06-19-2008 02:56 PM
Question about heater wiring in a Champ build Regis Theory & Design 2 02-28-2007 12:47 AM
Quick question about Vibro Champ speaker out vortex Maintenance, Troubleshooting & Repair 7 11-13-2006 07:21 PM
