Go Back   Music Electronics Forum > Instrumentation > Guitar Tech
Old 07-15-2009, 09:50 AM   #1
Jaguar HH noise
Hi,
I got some hum trouble with a Fender Jaguar special (HH).It starts humming as soon as the Vol. pot is turned down, turning up the Volume, the hum (almost) disappears.It hums on both circuits, Rhythm and Lead.
Any help much aprecciated, thanks,
Zouto
Zouto is offline   Reply With Quote
Old 07-17-2009, 11:47 AM   #2
Meanwhile I found out that the green positive signal wire to the output jack is completely touch sensitiv/microphonic.I'll try to use shielded cable instead.
The overall hum of the guitar is incredible in spite of grounded strings.
Zouto
Old 07-17-2009, 06:44 PM   #3
Pickup Maker
David Schwab's Avatar
Check all the grounds. Fender often doesn't run wires to the back of the pots, and only relies on them touching a control plate, or foil.
People with Jaguar basses were complaining about hum, and it turns out that there are bad ground connections, and some shielding foil that was never grounded.
Where ever Fender is having these instruments made, they are not doing a good wiring job.
I'd go ahead and rewire the guitar, and use some shielded cable as you mentioned.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is online now   Reply With Quote
Old 07-18-2009, 05:45 PM   #4
David: thanks, that's exactly what I'm going to do next week.
I'll post the results after havin' fixed that bad wiring hum.
Zouto
Old 07-23-2009, 12:16 PM   #5
Fixed
A complete rewiring with solid ground connections and shielded output cabel removed the hum completely and also braught a better overall sound.
The original crappy wiring had lots of "dead spots" and cheesy wires as usually used in cheapest guitars only.
Zouto
Old 07-23-2009, 01:49 PM   #6
Pickup Maker
Cool! It's a damn shame that they put such crappy wiring in those guitars.
__________________
Fender Jaguar Pickup Mounting martin manning Pickup Makers 5 02-11-2009 06:25 PM
fender jaguar help eggle Guitar Tech 4 08-13-2008 11:55 PM
Noise reduction Steve A. Fun with computers 9 12-26-2007 05:11 PM
Noise/ NightWinder Pickup Makers 10 09-03-2007 01:55 AM
Switching Noise rnbboy@comcast.net Maintenance, Troubleshooting & Repair 3 01-19-2007 10:37 PM
