Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers
Old 07-18-2009, 03:01 PM   #1
paf baseplate with 50 mm spacing
so guys is it possible to buy baseplate like this but with 50 mm spacing and only on 1 side holes for screw poles?
clown_luthier is offline   Reply With Quote
Old 07-19-2009, 10:01 AM   #2
Electricdaveyboy's Avatar
I had good results by drilling the 49,2 mm baseplate.
Electricdaveyboy is offline   Reply With Quote
Old 07-19-2009, 03:28 PM   #3
Pickup Maker
David Schwab's Avatar
Is .08mm really going to make a difference? That's only .04mm on eeach side.
__________________
Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel
www.sgd-lutherie.com
www.myspace.com/sgdlutherie
www.myspace.com/davidschwab
David Schwab is offline   Reply With Quote
Old 07-19-2009, 08:42 PM   #4
That looks like a Stewmac baseplate which I'm fairly certain is 50mm. If it's not a perfect fit, just ream the holes out slightly wider. As Dave says, 0.4mm on each side isn't that much on a baseplate.
It's much more an issue with covers because for aesthetic reasons you can't do any reaming but a slight widening of baseplate holes to accommodate 49.2mm and 50mm parts is no problem.
Zhangliqun is offline   Reply With Quote
Old 07-20-2009, 09:53 AM   #5
Spence's Avatar
You can tap those holes.
__________________
www.shedpickups.com
Spence is offline   Reply With Quote
Old 07-20-2009, 04:29 PM   #6
Supporting Member
belwar's Avatar
Quote:
Thats what she said!
belwar is offline   Reply With Quote
Old 07-20-2009, 07:44 PM   #7
Quote:
Thanx guys, i was thinking to buy guitar jones White and aged white bobbins to be closer to paf in color than with cream color.
he have only 50 mm in that colors.
Thanx for help evryone
spacing between eyelets on a board PRNDL Theory & Design 3 04-26-2008 08:41 PM
J an P Bass spacing mick Pickup Makers 15 04-13-2008 11:00 PM
Componenet Spacing zorro Theory & Design 6 04-11-2007 02:09 PM
mini humbuckers and spacing Earl Norton Pickup Makers 2 08-22-2006 09:45 PM
Tagboard spacing jaydawg 5 E 3 4 06-12-2006 02:00 PM
