Old 12-20-2006, 04:20 AM   #1
jcm900 50w low volume break up
I'm new to tube amps. My first is a Marshall 4100 JCM 900 the 50 watt version. It sounds great when it's turned all the way up, like marshalls do, but it's not as loud as i would expect and at lower volumes it breaks up to the point that it sounds too terrible to use.
Any advice as to what the cuase of this could be?
Smart ass marshall jokes are also welcome.
Thanks!
psycho_a_gogo is offline   Reply With Quote
Old 12-22-2006, 04:31 PM   #2
Amp Kat's Avatar
Could be several things but try patching the send to the return with a guitar cable. All of the grounds from the pots on this amp aren't tied together if I remember seeing a mod for this on the last one. Do all of the channels work correctly ? Footswitch jacks on these cause problems. The rectifier from the power tube heaters to the preamp heaters cause problems,gets hot and needs replacing with a larger rectifier. Bad tubes in either the preamp or power section do it also. Other than that you'd do better sending it to a tech who can go over it.
__________________
KB
Amp Kat is offline   Reply With Quote
Old 12-28-2006, 03:11 AM   #3
Mars Amp Repair's Avatar
if it breaks up at low volume, it could be a deficiency in the dc supply voltage to one of the stages....could also be biased wayyyy to cold & actually distorting at lower levels in the output stage (cutting off the tubes).
As AmpKat mentioned, the bridge that supplies DC for the preamp tube filiaments can bad, but it ususally manifests itself as the sound intermittently fading out as the filiaments dim. I suppose a situation could come up where the bridge was partially bad were supplying less than the nominal 6.3v to the tubes. I've not run into that yet, tho.
I agree with Amp Kat, it's probably an issue for a tech. glen
Mars Amp Repair is offline   Reply With Quote
Repaired Amp Break in? myque Repair and Restoration 12 01-06-2007 07:03 PM
Volume pot trouble dilly_Boy Maintenance, Troubleshooting & Repair 2 11-17-2006 07:22 AM
If it aint fixed, I'll break it! tboy Site News 11 08-21-2006 09:21 PM
Volume Reimer Tweed Builders 5 08-21-2006 03:20 PM
Volume question. Fredenando 5 E 3 3 08-10-2006 07:58 PM
