| | #1 |
| Senior Member Join Date: Jul 2008 Location: Auckland
| 20 w trainwreck based amp nearly completed
Just needs a bit more cosmetic detailing. Produces 20W RMS @ 1Khz with NOS Russian EL84Ms. Chassis solid heavy copper. Tonestack NOS mustard caps Mullard preamp valves. Has more gonads than a Tiny Terror, great cleans I am told. (I am not a guitarist) Will post sound clips as soon as I can get someone to do 'em. |
| | #2 |
| Supporting Member Join Date: May 2006 Location: Texas USA
Looks like the first preamp tube is next to the rectifier, the input jack is just below the output transformer, the impedance selector switch is in the opposite corner from the OT... I would think a layout like this would cause lots of problems.
__________________ WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel. |
| | #3 | |
| Quote:
This was my first valve based amplifier build started about a year ago, The layout did not follow my original plan because I ran out of space for a tremolo bottle & components, Thus the extra blanked off pot position. Since then I have built several other guitar amps of different types. I do understand audio layouts, I was designing SS amps for production in the late 1970s and before that I was employed servicing valve based and SS amps and equipment. | |
| | #4 |
| Junior Member Join Date: Aug 2009 Location: Indianapolis
So far this head looks awesome. I hope it sounds as good as it looks. Also, since you're not a guitarist am I correct in assuming people commision you to build these?
| | #5 |
| Member Join Date: Aug 2009 Location: Seattle, Washington
| trainwreck
I don't think I've ever seen a chassis made of copper alloy, looks cool. Will it petina after awhile? By the way, I think Ken Fischer only made his chassis out of aluminum because it doesn't mess with magnetic field lines... |
| | #6 | |
| Quote:
It always helps to let a prospective buyers try different types to help them decide what they would like me to build. I am active on: NZGuitars.com • View active topics As Anvil Amps Alan. There are photos of my other builds in progress there. | |
| | #7 | |
| Quote:
It should not oxidize. The product must have an acidic content because it turned the copper pink. I made the chassis from a piece of sheet which was lying around because I thought it would look nice and would be easy to work with. | |
| | #8 |
| Junior Member Join Date: Feb 2008
| tone
What would you compare the tone to?
| | #9 |
| I am not a musician so I don't speak tone. I believe that every individuals perception of tone is completely different and I make it my job to build amps to sound like the the new owner wants. Every guitarist who has tried it is impressed. There are lots of clips on YouTube with "Trainwreck Express" type amps. Similar circuit to Vox AC15. |
| | #10 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
Someone commented on the layout earlier. I've built two amps that have the OPT next to the input jack, and it's no big deal. What IS a big deal is the wires going from the power tube plates to the OPT, those have to be kept far from the input wiring, or separated from it by a shield. Same applies to the exposed bobbin of a drop-through OPT. I noticed that screened wire was used for the input jack, this probably helps. As for the rectifier snuggled up against the first preamp tube, I'd have thought that would cause a bit of hum.
__________________ "Transformerless is the way to go", said he, without a hint of irony. |
| | #11 |
The Trainwreck Express has an extra gain stage compared to the AC15. It is very difficult to stabilize and layouts that deviate from the original usually oscillate. It has three 12AX7s but only half of the third tube is used.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6AQ5-Based 5e3 Guitar Amp Build | Johnrcurry | 5 E 3 | 16 | 04-10-2009 03:53 PM |
| Can I use a 12AU7 based preamp with my SS power amp? | armstrom | Theory & Design | 4 | 04-30-2008 12:03 AM |
| Trainwreck on Ebay | tubetonez | Guitar Amps | 12 | 11-21-2007 02:02 PM |
| first build completed -thanks to all! | pbreyfogle | 5 E 3 | 4 | 06-30-2007 07:09 AM |
| Amp design based on Ampeg R12RT | chickenPlucker | Theory & Design | 7 | 04-26-2007 11:42 PM |
