| | #1 |
| Junior Member Join Date: Jul 2009 Location: USA
I have a Strat I've built with 2 humbuckers wired in a standard Les Paul set up (3 way switch, 2 volumes, 2 tones). I've had no problems with it over the past two years, however I'd like to change something on it and don't have the wiring knowledge to go about it. Anyone want to help? Instead of using the toggle switch found on a Les Paul, I'd like to use a 3 way slide switch instead. Problem is I don't know how to wire it. It is DP3T (double-pole/triple-throw), on/on/on with eight lugs, four on each pole. I'd like to have it be neck / neck-bridge / bridge. It's the bottom one in the picture below. Thank you to anyone that can help. |
| | #2 |
| Member Join Date: Aug 2008 Location: NSW Australia
Just did a quick google search and this popped up... Hermetic Hermetico: DIY - Guitar electronics for guitarists - III Don't think you need a DP3T. But a SPDT would do just fine |
| | #3 |
| Pickup Maker Join Date: May 2006 Location: Montclair, NJ
A DPDT wont give him the three pickup settings.
__________________ Those who create are rare; those who cannot are numerous. Therefore, the latter are stronger. - Coco Chanel www.sgd-lutherie.com www.myspace.com/sgdlutherie www.myspace.com/davidschwab |
| Bookmarks |
| Tags |
| guitar, wiring |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Ohm's Law and Power Slide Rule | Enzo | Theory & Design | 4 | 07-07-2009 12:44 AM |
| Slide on Connectors for Valve JR | BJosephs | Maintenance, Troubleshooting & Repair | 2 | 08-27-2008 01:56 AM |
| p-90 for resonator for slide | ShannonH | Pickup Makers | 0 | 03-10-2008 04:56 AM |
| Wiring a Tele Switch in a Strat with 2 Humbuckers? | Umfufu | Guitar Tech | 8 | 08-28-2007 09:57 PM |
| Slide Guitar + Pearly Gates? | spiffpeters | Pickup Makers | 0 | 06-15-2006 06:45 AM |
