Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp
Old 07-30-2009, 05:31 PM   #1
Amp project
Continuing on from the 5v winding in a previous post I am now looking at the electrolytic caps in the power supply filter section. I am building a Kalamazoo M1 and it calls for a 20-10-10 400v cap in the schematic. The chassis and PT are from an old Roberts tape player and all of the old electrolytics were rated at 300v. I have a 40-20-20 350v cap that I am wondering if it would work. The B+ is around 260v so would 350v be enough to allow for surge on the circuit?
Would be easy enough to go get three seperate cans, but I have this one and was hoping it would be OK. Is there a spec for the rectifier tube that limits what the capacitance for the first cap should be? IN this case the rectifier is a 6X4 tube.
Thanks
Rockn is offline   Reply With Quote
Old 08-01-2009, 02:40 AM   #2
I wouldn't push it any further than the 20u. Datasheet doesn't give a max value for a cap input filter but in the typical operation chart they show a 10u. 40 would be too much I'm guessing....a cap looks like a short to the rectifier before it charges. Draw too much current and the rectifier will zorch.
__________________
Gtr_tech is offline   Reply With Quote
Old 08-01-2009, 04:07 AM   #3
Cap source
Any idea where I could source a 20-10-10 450v cap? I have looked at quite a few sources and the closest I have found was one with an additional 10uf at the end. Not a big deal if I have to get separate caps, but the chassis is rather cramped.
Thanks
Old 08-05-2009, 05:46 PM   #4
hasserl's Avatar
Quote:
Thanks
Use the 20-10-10-10 cap and just leave one of the 10's unused.
Or open up the old can and remove the old caps and stuff new caps inside of it.
hasserl is offline   Reply With Quote
Magnavox Amp 175 project AaronP. Conversions 10 03-15-2009 10:51 PM
Finished my HiFi Amp Project bluesbubba Conversions 8 06-07-2008 05:12 PM
Garage Sale - SE amp project casey73 Flea Market 1 04-26-2008 03:20 AM
My Amp Project: 100W 2 Channel Amp Kramusha Theory & Design 11 11-01-2007 02:14 AM
amp project Hennie Build Your Amp 7 09-04-2006 05:10 PM
