Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 12-21-2006, 03:42 PM   #1
bulldogguitars's Avatar
Epiphone Valve junior
I just bought two of these little guys, and I gotta say they sound pretty darn good. But..... was wondering what I could do to clean one up. Meaning, have no breakup at a cranked level.
bulldogguitars is offline   Reply With Quote
Old 12-22-2006, 09:57 AM   #2
Supporting Member
Steve Conner's Avatar
Rip the guts out and replace them with the guts of a UL Twin?
Seriously, how are you going to get a big clean sound with only 3 watts available? I think about all you could do is reduce coupling capacitors to cut the bass and give the illusion of more power.
Steve Conner is offline   Reply With Quote
Old 12-22-2006, 02:01 PM   #3
I knew my options were limited. Ive started replacing the caps already and replaced the 12ax7 with a 12au7. Its better, and I can live with it now. Thanks
Old 12-22-2006, 02:20 PM   #4
Do you really think a Twin would fit in there? Might be a little cramped. Perhaps if we left out the reverb, that should be a space saver.
Old 12-26-2006, 06:41 PM   #5
If you go over to 18watt.com there is a very long thread about the VJ. It seems to be a favourite topic there. The thread is months old and has over 2K of posts. I can't be bothered since I wasn't there at the beginning and have never heard or seen one of these amps. There go your holidays.
clyde1 is offline   Reply With Quote
Old 12-26-2006, 08:12 PM   #6
In order to save your brain, a page twds end in the 18w thread uses this link as a summary of the basic mods: http://forums.birdsandmoons.com/foru...ad.php?t=32385
hope that helps, Captain.
The Captain is offline   Reply With Quote
Old 12-30-2008, 01:07 AM   #7
Did the 12AU7 really make any difference? I may want to try this!
Rayme is offline   Reply With Quote
Old 12-30-2008, 02:56 AM   #8
Supporting Member
Any lower gain pre-amp valve will clean up the signal going into the output tube (but then there goes your typical champy sound)
__________________
Old 12-30-2008, 03:08 AM   #9
TD_Madden's Avatar
changing preamp tubes are cheap and easy "mods".
TD_Madden is offline   Reply With Quote
Old 01-05-2009, 04:39 AM   #10
I put a 5751 tube in mine. Now I get some overdrive with it cranked. Clean otherwise.
ronh is offline   Reply With Quote
Old 01-05-2009, 12:45 PM   #11
Thanks for the info Ronh, looks like a cheap way for me to play with the sound!
Rayme
Old 01-05-2009, 07:53 PM   #12
12AX7 Swaps
Research shows I should be able to swap these tubes for the 12AX7 in my Epipy Jr..
5751
12AU7
6681
ECC83
CV492
12AV7
12AT7 Any comments???? Thanks, Rayme
how much gain can you get from an epiphone valve junior? gtrboy Guitar Amps 2 12-12-2006 10:53 PM
Simple master vol mod for Valve Junior Q. The Captain Mods & Tweeks 3 11-22-2006 05:59 PM
Epiphone Pacemaker EA-50T dprworld Vintage Amps 4 11-22-2006 12:51 AM
(new) Valve Junior head noisy problem The Captain Maintenance, Troubleshooting & Repair 8 11-19-2006 02:39 AM
Epiphone Valve Jr. Combo Help Hhabersat Maintenance, Troubleshooting & Repair 1 07-11-2006 03:03 AM
