Originally Posted by
Jay101
I have had this amp that i got used for about 2-3 years decided to change tubes and did so. man told me how to bias it with a multimeter???? done what i was told by checking across the only pot on the power board that shorted something tubes went extra hot i killed the stand by or power i cant rember fired it up again poped fuse.... got my self a rash of spares and started my novice tech work... turned down the pot and re tubed her had a slight buzz for several hrs but worked rather well. maby played 20hrs oh i should mention i have had high pitch feedback that is uncharacteristic of this rig...then all of a sudden it dies. well not exactly i can hear maby 2% volume all clean/dirty reverb ect seems in order it just has no power.main transformer seems ok i swaped power tubes with others and have the same condition.. caps,rectifier,heater????? any sugestions graciously accepted.Thanks in advance..101
agree that i probly goofed with the help of some bad advice and am verry intrested in learning how to repair this myself with help from willing people who know amps i do exelent solider work and know fair amount about other eletronics no parts in there i cant replace for a few dollars..i used to know this great teck but some how lost him. my labor is fee to me plus i enjoy the education. any parts to check or formatable test to run on them will be greatly appreciated.thanks in advance for any help
i pulled this from a previous thread.. also i replaced the rectifier it had a bad leg but didnot fix the amp main transformer voltage checks ok thanks for any help...101
Jtm 60 I am having power out issues with this amp i had a bad rectifier swaped him out and swaped tubes with other tubes they are all questionable i suppose pin outs on the tubes read as follows 2-7=6.97 vac ,3=482 vdc,4=479 vdc,5 = 38.7
to the OT i have 20vac in and am gitting 300mv out is this correct do i just have bad tubes , any advice greatly apperacited...101
