Old 08-03-2009, 12:00 AM   #1
Help with Sunn 200S
OK so I'm not really too good with the whole electronics thing..but I have a Sunn 200S that was given to me, and whenever I take the amp off stand by it blows the 3A fuse in the back. I took it apart and nothing looks blatantly wrong...so any ideas for the not so smart me? haha thanks for the help!
ineedhelp! is offline   Reply With Quote
Old 08-03-2009, 08:41 AM   #2
txstrat's Avatar
Welcome to the forum.
Try the amp with the power tubes pulled. Still blows fuses? If so, pull the rectifier tube too. What happens?
txstrat is offline   Reply With Quote
Old 08-08-2009, 05:19 AM   #3
ok o I tried pulling every combination of the tubes, and the fuse blows every time..very annoying...so I thought maybe the stand by switch was bad...? is that a possibility? and if so, then how would I go about checking that out? or is their something else I should be trying?
Any and all suggestions are appreciated!
Thanks
Old 08-08-2009, 09:24 AM   #4
txstrat's Avatar
What gives you the idea of the stand by switch being the culprit?
Does the fuse blow when you switch the amp into "play" mode? Or does the fuse also blow when the switch is in "stand by" mode, while you power it up?
Anyway, when the tubes are pulled and the fuse pops it's not a simple thing to solve either way (definitely not the stand by switch). You should bring the amp to a qualified amp tech, since the voltages inside a tube amp can kill you.
Old 08-08-2009, 10:59 PM   #5
Well, everything seems fine when the amp is turned on. The tubes warm up and all, but it is only when the amp is switched into "play" mode when the fuse pops. I probably take it to a service center but I'd like to have an idea of what the problem might be beforehand. Any help is appreciated! thanks!
Old 08-09-2009, 12:15 AM   #6
booj's Avatar
The standby switch connects the high voltage to the circuit. If the mains fuse blows you could have a problem with the power supply. If it blows with all the tubes removed it may have a wiring error from a previous fix.
booj is offline   Reply With Quote
Old 08-09-2009, 07:03 AM   #7
melvin's Avatar
Do you have a 3 amp slo-blo fuse in it?
I would suspect a bad filter cap. The rest of the power supply should be alright... It's also not the power tubes if it's going out with 'em pulled...
melvin is offline   Reply With Quote
Old 08-09-2009, 08:32 AM   #8
Pull all of the tubes out of the amp and turn it on. If the fuse blows when you flip the standby to ON then the power transformer could be bad, but it could also be a problem in the bias supply...a bad cap, diode, resistor, etc. It also might be a problem with the heater wiring.
If the fuse does not blow, then turn it off, put the rectifier tube back in, and repeat the process. If the fuse blows here, then it could be a bad rectifier tube, or a bad cap, or a bad choke.
If the fuse does not blow, then put the power tubes in and try again. If the fuse blows here then it could be a bad power tube, bad caps, bad choke, etc.
Quite a few things it could be, but it requires some testing to find out. If you don't know how to work on high voltage electrical equipment, then you should take it to a tech as tube amps are considered high voltage equipment, and they do have lethal voltages inside them.
If you do find that the power transformer is bad, then you can get a replacement at Triode Electronics among other places.
Greg
soundmasterg is offline   Reply With Quote
Old 08-09-2009, 03:11 PM   #9
Dave Curtis, dB AudioTech's Avatar
Better yet, rig up a light bulb current limiter, and stop feeding it fuses...
(just clipping a lamp across the empty fuseholder would work)
Dave Curtis, dB AudioTech is offline   Reply With Quote
Old 08-10-2009, 01:14 AM   #10
If the power transformer were bad, it wouldn;t care what the standby switch was doing. It would already be blowing the fuse.
heater circuits are live during standby, so we can rule them out.
The rectifier tube is live always as well, so if it were shorted, we'd know it even in standby.
the bias supply is always live too, so again, it must be OK.
Your output transformer could be shorted to frame or to secondary from the primary. Your choke could be shorted to frame. Your filter caps could be shorted or installed backwards. You could have an arcing tube socket.
__________________
Old 08-13-2009, 03:47 PM   #11
Quote:
While it would seem that the rectifier is good, it might not be. I have a 200s that did the same thing. Everything looked good until the standby was flipped on, then the fuse blew. Replaced the recifier tube and it worked fine.
John! is offline   Reply With Quote
Old 08-14-2009, 02:05 AM   #12
Fair enough.
__________________
Sunn 200S Rknbkr12 SUNN 6 12-31-2008 11:22 PM
Sunn 200S drawing too much current at idle ddm Maintenance, Troubleshooting & Repair 15 04-08-2008 01:23 AM
200S pictures knob SUNN 3 03-12-2008 07:43 PM
Sunn 200S gbono Maintenance, Troubleshooting & Repair 4 09-25-2007 01:04 AM
200S Power Tranny Rick Erickson SUNN 14 11-26-2006 08:58 PM
