| | #1 |
| Junior Member Join Date: Dec 2006
| No sound coming from a Marshall TSL 100 head
The AC indicator glows perfectly fine, and all the tubes are lighting up fine as well. I also checked the Cab with a different head and it works perfectly fine as well. Does anyone have any idea what the problem could be? Thanks |
| | #2 |
1. Is the output MUTE button pushed in? 2. Pull the HT fuse and see if it is blown. HT means high tension - another term for high voltage. That is a 1 amp SLOW BLOW fuse. Radio Shack has them. 3. If that fuse is blown, it MIGHT just be a fuse, but most of the time when that fuse goes, it means one of the power tubes is failing. Beyond that, it could be many other things, like wires off, broken solder joints, open resistors, etc. |
| | #3 |
| Senior Member Join Date: Jul 2006 Location: Baton Rouge,LA
I'm also with ENZO that the HT fuse is blown. Seen it several times on these amps.
__________________ KB |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| No sound coming from Blues Jr. | io256 | Maintenance, Troubleshooting & Repair | 7 | 03-05-2010 12:14 AM |
| No sound from Silvertone amp head | davohilts | Maintenance, Troubleshooting & Repair | 5 | 09-02-2006 09:04 PM |
| Which is the better head to Buy? | TRT | Guitar Amps | 0 | 08-24-2006 04:04 PM |
| No sound from this amp, only HUM! | slidincharlie (Carlo P) | Maintenance, Troubleshooting & Repair | 8 | 06-30-2006 06:13 AM |
| Amp does not sound right... | Demond1525 | Maintenance, Troubleshooting & Repair | 1 | 06-05-2006 09:06 PM |
