| | #1 |
| Junior Member Join Date: Sep 2008
| Need help with AC128 transistors
I've decided I want to get into pedal building and figured the place to start would be a fuzz face given how simple the circuit is and how easy they are to mod. I've managed to obtain quite a few AC128 transistors from various suppliers in the hope that I can get a matched set of "good ones" but when they got here I realized I don't know what is what. How can I tell which lead is C, which is B, and which is E? What is the best way to test for leakage? How do I test for "matched sets" I know quite a bit about valves and tube amps and have built and modified several amps so I know a bit about electronics, it's just that trasistors are a new realm for me. Any help you can give me would be great. |
| | #2 |
| www.geofex.com - Technology of the Fuzz Face There is also an article about selecting the "right" transistors. Connections of the AC128 are E-B-C clockwise when you look at it from the bottom. Cheers, Albert |
| | #3 |
| Senior Member Join Date: Jul 2008 Location: Auckland
The dot or arrow mark is the collector, the centre lead is the base on vintage germaniums. Some like OC71 are arranged in a line, AC126 etc. are in a triangle arrangement. Last edited by unparalleled; 08-04-2009 at 09:43 PM. Reason: additional info. |
| | #4 |
| Member Join Date: Dec 2008
Anytime you need to know something about a transistor or IC, all you have to do is google the datasheet. For the AC128, just google AC128 datasheet. You will get a bunch of results. Here is one. http://www.datasheetcatalog.org/data.../493012_DS.pdf It shows you the pin configuration and a lot more. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Germanium Transistors! | Voodoorider | Guitar Effects | 5 | 11-14-2008 06:57 PM |
| How do you install Transistors | Jam | Maintenance, Troubleshooting & Repair | 2 | 06-26-2008 07:11 AM |
| Anyone know anything about transistors? | Liam | Maintenance, Troubleshooting & Repair | 33 | 11-10-2007 10:27 AM |
| 'Matching' transistors | The Captain | Guitar Effects | 8 | 06-06-2007 07:28 PM |
| CV7003/NTN7917 transistors??? | tonezoneonline | Guitar Effects | 4 | 07-27-2006 04:26 PM |
