| | #1 |
| Junior Member Join Date: Jul 2009
| JC 120 Line IN
Anyone know how to add a line in to an older Roland JC 120. I want to be able to use a stereo effects unit directly to the power amp side, bypassing the JC 120 preamp? The amp's SN 697711, not sure of the age, probably 79 or 80
| | #2 |
| Senior Member Join Date: Jun 2008
The volume pots are concentrick 100k/10k. Try inputting the signal through a 1-1-ufcap and a 10k resistor to the hot side of the 10k section.
| | #3 |
| Junior Member Join Date: Aug 2009
I had a '77 or '78 model in the late '80's, & I believe I split the path at C26 & C126, but I may be mistaken. I used the 4 jacks (2 ext. speaker, line out, & footswitch) on the back for stereo out & stereo in. I hooked up a DIN or MIDI jack to control the reverb, chorus, & distortion. Since the 4 jacks are all normally closed jacks, they worked perfectly. Initially, I used the amp's preamp & inserted a Quadraverb in the loop. Later on, I switched to a tube preamp into the Quadraverb, totally bypassing the JC120 preamp. Another suggestion would be to switch out the Roland speakers Celestions or speakers of your choice. Steve |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Crate Turbo Valve 120 Schematic? TV-120 | RWood | Schematic Requests | 9 | 08-21-2009 08:40 PM |
| No chorus effect on JC-120 | jzr85j | Maintenance, Troubleshooting & Repair | 0 | 03-21-2009 03:35 AM |
| Roland jc-120 | Mikelib | Maintenance, Troubleshooting & Repair | 10 | 02-18-2009 06:11 PM |
| JC 120 Reverb | whojamfan | Mods & Tweeks | 12 | 11-10-2008 06:25 AM |
| line 6- need help | Mshredder | Guitar Effects | 3 | 08-13-2007 02:35 PM |
