| | #1 |
| Member Join Date: Jul 2007
| How much thickness does tolex add?
I made a back panel for an amp and I think I may have a done a nice job on exactly the wrong thickness wood. I was going to order the fender tolex and water-based glue from Mojo, if that helps. Thanks |
| | #2 |
| Junior Member Join Date: Jul 2009
The thickness would depend somewhat on the style of covering you pick. The smooth would be thinner than the rough pebble grain. Do you think you cut your part too small? |
| | #3 |
| Assumptions...
Thanks for the reply! I have a music man 210-65 that I've made an upper rear baffle for. I made this bafffle out of 1/4 baltic birch but it appears that maybe 3/8" is the right material --> I went with 1/4" because all Fender seem to be 1/4". The stock lower baffle is slightly less than 1/2" (.44") and I was thinking that 1/16" per side of tolex would bring it up to the proper thickness. In any case, I bought 3/8" and the tolex comes in a few days so I will report which one is right when I have all the pieces in hand and put a caliper on it. |
| | #4 |
| 3/8" for Music Man rear baffle
Definately 3/8", the baffle looks great and I just used regular contact cement5 because the mojo stuff was too pricey. mojo tolex = .030" |
| Bookmarks |
| Tags |
| add, additional, thicker, thickness, tolex |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Tolex which one......... | fubar99 | Cabinetry | 1 | 12-16-2008 11:43 PM |
| How thickness of eyelet borad used? | kldguitar | Build Your Amp | 1 | 05-21-2008 01:16 PM |
| Pink tolex | Bandit | Cabinetry | 1 | 01-18-2008 09:26 PM |
| What have YOU used to glue Tolex with? | nicksorenson | Build Your Amp | 4 | 08-30-2007 05:31 PM |
| OT Laminations - does thickness really matter? | Gregg | Theory & Design | 3 | 09-27-2006 10:26 AM |
