Go Back   Music Electronics Forum > Instrumentation > Guitar Tech > Pickup Makers > Tools and Coil Winding Gear
Old 08-09-2009, 05:01 PM   #1
Counters from Advanced supply
I have been researching counters and trying to get a handle on what works best, saw these and wonder if they would work ok.
Bill
Bill Scheltema is offline   Reply With Quote
Old 08-09-2009, 05:40 PM   #2
Impossible to say. Datasheet required.
Joe Gwinn is offline   Reply With Quote
Old 08-09-2009, 07:28 PM   #3
Shepherd's Avatar
Most likely discontinued and been sitting on a shelf 5 years, something similiar http://www.kep.com/catalog/ii/pdf/kal-din.pdf
Shepherd is offline   Reply With Quote
Old 08-09-2009, 09:25 PM   #4
Quote:
If the internal lithium battery isn't exhausted, this ought to work as a turns counter. It's similar to the CUB3, but with a few more options.
Old 08-18-2009, 03:07 AM   #5
RedHouse's Avatar
Quote:
Speaking of expired batteries, I got a couple CUB4's once that had dead batteries, I opened them up with the intention of replacing the batteries but instead just ended up removing them and hooking up a LM317 setup for 3.3V output.
__________________
-Brad
ClassicAmplification.com
RedHouse is offline   Reply With Quote
Old 08-18-2009, 03:37 AM   #6
Quote:
That'l work, if the dead batteries didn't leak.
Old 08-18-2009, 11:56 PM   #7
Try the intersil 7207 single chip counter. add a 4 1/2 digit display and instant
counter. It is still available from several sources for a few bucks, I got mine as a free sample. Very easy to use you can cascade two for very high counts. use a phototransisror led interrupter or reed switch to trigger.
Amplexus is offline   Reply With Quote
Old 08-21-2009, 10:36 PM   #8
chevalij's Avatar
Looks like a Red Lion cub 3. Probably work fine.
__________________
www.chevalierpickups.com
chevalij is offline   Reply With Quote
The Stompbox Cookbook: Build Advanced Effects for Electric Guitar & Bass tboy Content 0 08-03-2008 09:32 PM
Electronic counters help. madialex Tools and Coil Winding Gear 30 06-01-2008 07:19 PM
AC filament supply? cminor9 Theory & Design 22 05-13-2008 09:38 PM
Counters NightWinder Pickup Makers 11 09-30-2007 03:50 PM
Red Lion Cub3/3r counters on ebay David King Tools and Coil Winding Gear 1 03-03-2007 03:41 PM
