Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 08-10-2009, 04:33 AM   #1
gayler's Avatar
6v6, 6f6
Can they be interchanged?
gayler is offline   Reply With Quote
Old 08-12-2009, 07:30 PM   #2
Quote:
Doesn't look like it.
Compare the data sheets and the application data if very different in almost all cases.
A.C.CHILDRESS is offline   Reply With Quote
Old 08-13-2009, 03:42 AM   #3
gayler's Avatar
Thanks for the reply. I could see voltages are lower, but I didn't know if they would live. Also didn't know if the amp, 5F1, would be damaged.
Old 08-19-2009, 09:24 AM   #4
Supporting Member
Pin-out's the same. Bias is about the same. Plate voltage might need to be watched but it shouldn't be an issue with a 5F1 if you were idling the plate at about 340 I reckon. The recommended plate dissipation is 4.5W, so just run a slightly higher cathode resistor, and/or zener down the B+ a bit if it redplates.
6F6GT/G @ The National Valve Museum
__________________
Old 09-05-2009, 03:46 AM   #5
...6F6 is a 'true' five-element pentode, while the 6V6 is a beam tetrode...which means different plate Eb-Ib "knee" characteristics for sure.
__________________
Old Tele man is offline   Reply With Quote
6l6 ok with 6v6 OT ? allsavy Mods & Tweeks 4 02-02-2009 09:22 PM
using a 6F6 instead of 6V6 to lower power PRNDL Theory & Design 4 09-12-2008 05:21 PM
6J7, 6F6, 5W4 single ended amp hearforever Theory & Design 6 07-08-2008 11:19 PM
EL34 vs 6V6 daz Theory & Design 8 06-25-2008 08:58 AM
6v6 Ab2????? Satamax Theory & Design 9 07-14-2006 12:57 AM
