| | #1 |
| Member Join Date: Jul 2006 Location: Upstate NY
| Filter cap limit?
What is the limit on filter capatity to get rid of hum? Specifically, I have a 2-6V6 amp that has a good amount of 60z hum that I can get rid of with an 80mF cap to the b+ to the OT. A 22mF doesn't do the job too well. I know there is something going on that limits capaticitence. Any help would be appreciated. Thanks. Mike |
| | #2 | |
| Lifetime Member Join Date: May 2006
| Quote:
The repetitive peak current on silicon rectifiers is in general huge, so there is no effective limit on the capacitance of the first capacitor if you use silicon rectifiers. If you're getting 60Hz hum on your output, you have a different problem. A full wave rectifier makes the lowest frequency be 120Hz, two pulses of power per AC cycle. If one of the rectifier pathways is open, that gives you 60Hz hum. 120Hz ripple makes the existing capacitors twice as effective because it's only half as long between power pulses from the rectifiers. It's worth checking to see whether you're getting 60Hz ripple or 120Hz ripple - they're different problems. | |
| | #3 |
Thanks for the response. I'm using a 5Y3 in standard Fender configuration as found on a Music Master Bass as that is the chassis that I wired as a 6G2. I'm not sure if that is full or half wave, so I don't know what the problem is. But if I replaced the 5Y3 with (3) 1N4007s in series on each leg (red wires) coming from the PT could I then use the 80mF cap? Mike |
| | #4 | |
| Senior Hollow State Tech Join Date: May 2006 Location: Denver, Colorado
| Quote:
Those amps had fairly low voltage B+ though and it would be way much worse with a 5Y3GT!! Stick with two series wired 1N4007 solid state diodes in each leg with this amp if you are using the stock power tranny. That way you can run 100uF to 200uF pretty easily of you wanted to. | |
| | #5 |
Bruce, Its been such a long time since I got this amp I think I may have put the tube rectifier in and forgot. The PT has 5v taps, so either it already had them or I replaced it....the joys of age.... but the socket hole looks a little bigger than the socket so I suspect I put it in myself. Anyway, all I needed to know was that the uF limit is much greater with diodes so now I'm cool with it. Thanks. Mike |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Standard Amp "body" and "Limit" controls - what the hell are they? | Ptron | Theory & Design | 7 | 10-02-2006 06:32 PM |
| GZ34 with 50uf filter cap???? (Marshall Lead 20) | greg | Theory & Design | 2 | 09-13-2006 07:39 PM |
| Parallel vs. series vs. one filter cap | Chris333 | Theory & Design | 4 | 08-29-2006 07:03 PM |
| Filter cap bleed resistor with 5AR4? | Normster | Theory & Design | 3 | 07-04-2006 01:19 AM |
