Hi Fender Man
there could be several reasons that 'Fender' tank isn't working:
1) It could be the wrong tank for the circuit (wrong input impedance maybe; - has the tank got numbers on the side - like '4EB2C1B' or something like that? It could be a tank that is designed to be driven by a tube through a transformer, instead of straight off a transistor/opamp)
2) It is okay to use in the amp but:
a) the tank is broken (broken transducer coil or spring - test the tank's input, and the tank's output for continuity with an R-meter); or
b) one of the cables going to or from the tank need fixing (test the cables for continuity with an R-meter)
c) the circuit driving the tank needs fixing (bad transistor/opamp or some other broken component; - take it to a tech)
LinkBack URL
About LinkBacks
