Go Back   Music Electronics Forum > Amplification > Other Amps
Old 08-11-2009, 06:29 PM   #1
Yamaha MG24/14FX
I'm trying to find out what the transistors are on the front end of the pre amps. The SMD code is "CGB". And yes I'm pretty certain that's the code.
It's printed very clear. But I could be wrong. I've checked serveral code books on line but no luck.
Twist is offline   Reply With Quote
Old 08-12-2009, 01:37 AM   #2
Closest I can find is MG16/6FX in my files. I will look further for verification. The channel inputs there, if it is similar, have four transistors per channel. They are all NPN, but for whatever reason of two differing types. the two toward the + rail and whose collectors connect directly to the op amp inputs are 2SC3324. the other two, the ones closer to the neg rail are 2SC2412.
Assuming some family resemblance between your model and this, I hope that helps.
__________________
Yamaha EMX660 kmiller1610 Maintenance, Troubleshooting & Repair 4 07-21-2009 02:18 AM
Yamaha T50 C lowell Theory & Design 6 03-10-2009 01:24 AM
Yamaha G5 schematic...anyone got one? bobsamps Schematic Requests 0 02-12-2009 03:23 PM
yamaha J-55 schematic tytech Schematic Requests 0 11-15-2008 11:12 PM
Yamaha wiring luis Guitar Tech 5 10-13-2008 02:41 PM
