Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 08-14-2009, 02:08 PM   #1
Changing Vibroluxe Reverb Custom tubes
Anyone has recomendations wich powertubes I should use??
Jagal is offline   Reply With Quote
Old 08-14-2009, 02:16 PM   #2
Use tubes that bias up within tolerance, without having to mod the amp, the bias adjust resistor is tucked away behind the faceplate PCB (PITA). The stock Sovtek WXT don't sound too bad in these amps at 30-35mA (measured with the vibrato SWITCHED off)...I usually get a few sets and just run through them with a bias probe until I hit a good plate current & tone.
I'd be looking more to sub the Sovtek 12AX7WA for better sounding tubes, they're a bit weak sounding.
MWJB is offline   Reply With Quote
Old 08-16-2009, 09:22 AM   #3
My recollection is that the reverb always sounds weak on these. It's the circuit. There's plenty of gain at the recovery end, there's just no drive signal 'cause Fender futzed with the thing. The only easy fix that I've been able to do is make sure the reverb driver has plenty of gain. I sub a 12AX7LPS.
Sweetfinger is offline   Reply With Quote
Old 08-18-2009, 06:37 PM   #4
thanks for the infos! IŽll ty that
Replacement tubes for Custom Vibrolux Reverb mottaz Guitar Amps 2 10-06-2008 05:32 PM
old amp, changing tubes milothicus Maintenance, Troubleshooting & Repair 23 09-02-2008 04:31 PM
changing my tubes!!! help!!! cris9288 Guitar Amps 15 03-01-2008 11:16 PM
SF Deluxe Reverb - amp tone changing or is it me? Chippsta Guitar Amps 2 11-29-2007 12:51 AM
Custom 64' Super reverb pics truetone Build Your Amp 6 04-20-2007 07:40 PM
