| | #1 |
| Junior Member Join Date: Aug 2009
| mark hammer's chaos help!
Hi, Im new to this forum. I have just finished my 2nd build of mark hammer's chaos. I thought Ill build a new one since the first one I made was messy and had a lot of hiss. The problem Im having now is it just sounds like bypassed and I didn't install a bypass switch! I think it works because i don't get any sound when its not connected to the adapter. The vol, tone and gain knobs work but there is no distortion! just a change in the sound. Anyone who might know what could be the problem? I tried changing the IC (TL072p, I used Paul Marossy's layout) but its still the same. |
| | #2 |
Sounds like there are a lot of possible troubleshooting steps to check off. #1 - You built this from Paul Marossy's layout. You etched the board yourself? Are you confident that all traces are as they should be with no bridges and no breaks? #2 - Any possibility of cold solder-joints? #3 - Are you sure the power is wired up correctly? #4 - Are you sure the jacks are wired correctly? Maybe the best place to start is with the debugging FAQ here: Debugging - DIY_Wiki and here: DEBUGGING - What to do when it doesn't work Get back to me with a status report, and we'll continue. |
| | #3 |
Thanks forthe reply Mark! I'll go over it asap.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Mesa Mark V review | rabies | Guitar Amps | 0 | 01-03-2009 05:59 PM |
| Markbass Little Mark II | Alex R | Maintenance, Troubleshooting & Repair | 9 | 12-28-2008 01:34 PM |
| Mesa Mark 3 gone bad again | sixstring63 | Maintenance, Troubleshooting & Repair | 0 | 12-15-2008 02:05 AM |
| Mark IV EQ | Gregg | Theory & Design | 4 | 03-22-2007 10:43 PM |
| Mark III biasing | AtomicMassUnit | Maintenance, Troubleshooting & Repair | 3 | 09-05-2006 10:05 PM |
