Go Back   Music Electronics Forum > Amplification > Other Amps
Old 08-18-2009, 05:06 PM   #1
Behringer Europower PMX2000 clipping
I assume the PMX2000 has automatic circuit protection that cuts out the amp if you push it too much. Mine started clipping out a few shows ago and got progressively worse. Now it will cut out at very low levels. If I plug directly in to the power amp input from another mixer it is fine but if I run through the mixer/preamp, it cuts out frequently. Any idea what the problem is and how to fix it?
auditoriumb is offline   Reply With Quote
Old 08-19-2009, 02:54 AM   #2
My first thought is a collapsing 15v power rail. or a failing op amp.
The only place needing protection from clipping is your speakers. The power amp will have overcurrent protection and a crowbar across the output for DC. But the power amp works. SO the mixer would be the problem if powr supply is OK. if all input channels are affected, then I l;ook in the master section
__________________
Tags
behringer, europower, mixer, pmx 2000
Behringer PMH1000 Europower Schematic Please devilock1138 Schematic Requests 4 12-12-2009 10:19 PM
Behringer Europower PMH 1000 heidel Schematic Requests 1 07-26-2009 10:35 AM
Behringer PMX2000 Fried! brant Maintenance, Troubleshooting & Repair 3 03-30-2009 08:35 PM
[Help] Bihringer EUROPOWER PMX2000 smarkies Other Amps 12 02-18-2009 02:17 AM
Behringer PMX2000 e_c_mccollum Other Amps 7 05-04-2007 08:36 AM
