Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 08-18-2009, 08:53 PM   #1
tedmich's Avatar
OT protection diodes SR-2873?
whats the best replacement for the Peavey SR-2873 which I believe is an old Motorola MR250-2, 2KV 250mA fast recovery diode?
2 series UF4007?
Vishay RGP02-20E-E3/54 ? maybe discontinued...
Rectron R2000F-B
http://www.rectron.com/data_sheets/r1200f-r2000f.pdf
more voltage?
http://www.rectron.com/data_sheets/r2500f-r5000f.pdf
on the Rectron's is 200mA enough?
tedmich is offline   Reply With Quote
Old 08-19-2009, 02:01 AM   #2
You could always call PV and have them send you the exact part.
__________________
Enzo is online now   Reply With Quote
Old 08-19-2009, 03:47 AM   #3
I usually use the Rectron R3000, which is a 3kV diode, but not fast recovery, which is REALLY not necessary.
Then again, transient suppressor diodes usually aren't necessary at all, unless you are protecting cheap output transformers as seen on many new tube amps.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 08-19-2009, 04:36 AM   #4
Or when the customer uses cheap speaker cords, or guitar cords for speaker cords, or has loose wiring in his cabs, or forgets to plug his cabs in, or plugs them into the FX return...
__________________
Old 08-19-2009, 12:49 PM   #5
I use always for this application , the GP02-40 , on europe it's available thru RS components and others.
oskar.
oskar is offline   Reply With Quote
Old 08-19-2009, 08:34 PM   #6
Supporting Member
Steve Conner's Avatar
I think three series 1N4007s is a common bodge. Two to get your 2kV PIV rating, and a third one for luck.
I agree that they don't really need to be fast recovery, since they shouldn't normally even be conducting at all.
I'm sure I remember using those GP02-40 diodes in a FWCT rectifier. I wanted fast recovery because I believed that thing about FREDs sounding better at the time.
Steve Conner is offline   Reply With Quote
Old 08-20-2009, 10:48 PM   #7
tedmich's Avatar
Quote:
Originally Posted by Steve Conner View Post
I I believed that thing about FREDs sounding better at the time.
its not true?
FRED Durst, as an example, does sound terrible...no one ever recovered quickly from hearing him for the first time...
audiophiles do love their Stealth diodes...
Gallien Krueger 700rb Protection Mode buffalo Maintenance, Troubleshooting & Repair 3 12-01-2008 09:47 PM
Protection? daz Theory & Design 17 06-26-2008 01:00 AM
Output transformer protection fuses signalpaths Mods & Tweeks 3 06-04-2008 06:04 PM
1n4007 spike protection lowell Theory & Design 37 05-01-2008 12:48 AM
Ampeg V4 shorted diodes- primary OT Normybaby Maintenance, Troubleshooting & Repair 3 03-05-2008 01:56 AM
