Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 08-21-2009, 08:29 PM   #1
tubby's Avatar
jcm 800 clone for bass
Hi Everyone,
i just finished a jcm 800 (2203) clone and tweaked the circuit for bass:
- 0.1µF coupling caps except for the first coupling cap (0.047µF) and
tonestack (500pf, 0.047µF, 0.1µF).
- i omitted all of the treble peaking RC combinations (2x470k+470pf),
brightness cap on preamp pot.
The rest is stock 2203.
Upon first test, the amp sounded very thin, almost no bass, tone controls were rather uneffective, especially the bass control. distortion sounds awful, but it's not the farting-out type which would possibly imply blocking distortion. However, typical volume for a 100 watter is definitely there.
B+ and tube voltages are all in ballpark ranges, known good pre- and power tubes. Bias is set at 65% max dissipation. I went over the circuit again and again.
Could this issue be due to the (too) large coupling caps? What other component could it be? defunct OT?
thx for any ideas!
tubby is offline   Reply With Quote
Old 08-21-2009, 10:16 PM   #2
Supporting Member
loudthud's Avatar
If you are looking at the 2203 circuit, you must not be looking for a clean sounding bass. The caps in the tone stack should go back to stock values. The one that connects to the junction of the treble and bass controls will increase bass slightly if bumped up to 0.1uF. You should take another look at the treble peaking caps. Try them one at a time and experiment with the values. Amps like this need a little treble peaking somewhere or they sound pretty dull even for bass.
__________________
WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
loudthud is offline   Reply With Quote
Help on my jcm 800 mods BeëlzeM Maintenance, Troubleshooting & Repair 16 08-11-2009 01:28 AM
marshall JCM 800 Bass series strange problem adaramit Maintenance, Troubleshooting & Repair 1 03-18-2008 06:02 PM
jcm 800 wierdness p3bufny Maintenance, Troubleshooting & Repair 3 02-06-2008 02:28 PM
Marshall JCM 800 keysnleslie Maintenance, Troubleshooting & Repair 10 06-01-2007 03:54 AM
JCM 800 No Power darkstar8194 Maintenance, Troubleshooting & Repair 4 05-17-2007 08:03 PM
