Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 08-22-2009, 05:32 PM   #1
output trans impedance
I've recently picked up an old radio chassis.
It has a cute vintage SE Stancor OT that I would like to utilize. my guess is its about 4 watts and is labled 4000 ohms primary and 8 ohms secondary.
funny thing is it was coupled to a 6v6gt.
in my limited experience a 6v6 wants 5K on the primary right?
I can't find any date codes on the chassis or components that i can decifer, but from the wooden spools that the dial strings go thru and a repair tag dated oct 1954 from monroe radio repair i'm guessing this thing was made in the early 40's and may have had a field coil speaker at one time.
the Stancor looks like its not original to the chassis, but i can't prove it.
I guess my question is would this be suitable to use on a 6v6 se amp?
would I be better off using a 6k6 and a 16 ohm speaker?
also in the same box of stuff i have a MM axiom OT for a tweed champ (FTCHO-5) I was told this would be suitable for a Princeton 5F2A if I use a 4 ohm speaker, any opinions on that info would be greatly apreciated too.
thanks
stingray_65 is offline   Reply With Quote
Old 08-22-2009, 09:24 PM   #2
Supporting Member
Quote:
Most tube datasheets give a value around 8k, but anything between 5k and 10k will work and anything between 6k6 and 8k will sound good in a tweed champ/princeton
Simplest way of doing it
__________________
Old 08-22-2009, 11:06 PM   #3
Or just use a 6V6 and a 16 ohm speaker keep the plate voltage down. Unless you think 6K6's sound better than 6V6's
Chuck
Chuck H is offline   Reply With Quote
Old 08-23-2009, 01:38 AM   #4
tnks
Stancor output trans...any knowledge of this unit? PremiumPlus Tweed Builders 8 06-01-2009 10:59 AM
NFB Lowers Output Impedance? tbryanh Theory & Design 5 05-02-2009 08:27 PM
need some help identifing output trans mark enger Guitar Amps 1 10-08-2008 09:45 PM
How to change an amp's output impedance jondanger Mods & Tweeks 25 03-09-2007 05:57 PM
5f1 output trans wiring tubelovin Tweed Builders 4 09-28-2006 03:28 PM
