| | #1 |
| Member Join Date: Feb 2007
| Home made rectifier replacement
Yesterday I made a couple of rectifier tube replacement plug ins. I used a couple of old tube sockets and six 1N4007 diodes. I wired 3 diodes in series then ran them from pin 4 to pin 8 and pin 6 to pin 8 with anodes pointing toward pin 8. The question is what to do about a cap for the socket? Sure enough if I leave the diodes exposed someone (me) will put their fingers in it or drop something metal in it. Can I fill the sockets with some sort of non-conductive epoxy? Thanks! |
| | #2 | |
| Senior Member Join Date: Apr 2008 Location: PDX
| Quote:
![]() ![]() ![]() you are aware that the voltages go up quite a bit with the tube -> SS rectifier switch right? | |
| | #3 |
| Member Join Date: Aug 2009
Hey Axtman, Hope you meant you have the 1N4007 CATHODES pointing towards pin 8! I'd throw in a couple small 22 ohm 1/2W flameproof resistors in series w/ each leg. For over-current protection. But that's me. |
| | #4 |
| Junior Member Join Date: Jun 2006 Location: New Brunswick, Canada
Try the lid from a Kodak 35mm film can as a cap. You can glue it on with hot glue or superglue.
| | #5 |
Well I mean that the arrow on the anode is pointing to pin 8. I guess that I should have said that the cathode end was on the pin 8 side. Yes I am aware that the voltage goes up. I might try the resistor trick. I found that the clean 35 mm caps fit snugly on the tube base. This works out because then I can service or mod the thing if I want. Epoxy just seems like a mess to me. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| More home made attenuator questions | Regis | Theory & Design | 12 | 03-15-2009 10:41 PM |
| Home made Attenuator questions | Regis | Mods & Tweeks | 29 | 11-03-2008 02:25 AM |
| Home made guitar preamp? | jaywalker | Guitar Tech | 6 | 07-20-2008 02:19 PM |
| Home- made showman | nwguy | Debugging Your Build | 2 | 07-06-2007 07:39 PM |
| A Home-Made Triode!??! | Don Symes | Tubes (Valves) | 6 | 03-01-2007 10:32 AM |
