Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 08-25-2009, 08:21 PM   #1
Peavey Triumph60 Adjustable Bias
I would like to add a pot to adjust the bias of a Triumph 60. I'm relatively new to this so I wanted to check to see if I'm on the right track. I was thinking about changing R81 to a 10k resistor and a 50K pot. Will that work?
Thanks
Bryan
rblp is offline   Reply With Quote
Old 08-28-2009, 05:24 AM   #2
No, it won't.
That resistor has to form a voltage divider with another for the adjustment to do anything. The upper resistor in said voltage divider is R65 over in the power supply, next to F3 and CR14. it is only 470 ohms, so pretty much othign you do with that 10k and 50k will have any effect. Well, if you turn the pot to zero leaving only the 10k, that would reduce the bias voltage about 2 volts. Not enough to matter much.
You need to increase R65 to something like 3k or more. 3.3k is a standard value as is 3.9k. With that change, you r pot and resistor will make sense.
__________________
Old 08-28-2009, 05:26 AM   #3
Oh, and here is a pdf file of the schematic. Maybe a little easier on the downloads, and easier to work with.
__________________
Old 08-28-2009, 06:06 AM   #4
Thanks! I appreciate your time looking at this.
Bryan
Old 08-29-2009, 05:20 PM   #5
Enzo,
Thanks again!. It worked. I put a 3.3k in R65 and I had to use a 100k pot for R81. This and some new caps brought that old amp to life.
Bryan
On bias /adjustable fixed catnine Theory & Design 4 06-17-2009 07:46 AM
Adjustable Bias on Rivera Chubster/Clubster OldFarb Maintenance, Troubleshooting & Repair 2 02-10-2009 02:46 AM
Adjustable bias on Valveking msclford Mods & Tweeks 9 12-07-2008 04:28 PM
Adjustable Bias in 5E3 circuit KingCameron Theory & Design 8 11-13-2008 09:35 PM
Roland Bolt 100 - Adjustable bias marson Maintenance, Troubleshooting & Repair 2 12-08-2007 11:42 PM
