Results 1 to 11 of 11
Thread: Prototyping board
    Feb 2008
    132
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Prototyping board
    Is it even possible/worth building a prototyping board to prototype vacuum tube amps? I mean I'm working on a 36VCT based one to play with a certain 12AU7 design (9V battery powered distortion pedal, I have a slightly different idea in mind on the same lines), but prototyping full 600V 6L6 tubes etc etc ....
    0 Not allowed! Not allowed!
    Old Timer defaced's Avatar
    Dec 2006
    York Pa
    1,394
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I do it on poplar board with copper nails for preamp circuits that sit at around 400v DC on the high end. All of the high voltage stuff is on the power tubes which with minimal effort you can do point to point.
    -Mike
    Feb 2008
    132
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Quote Originally Posted by defaced View Post
    Nods. I'll be playing with preamp tubes and cascading distortion at around 9-15V, hence the 12AU7.
    Feb 2008
    132
    Thumbs Up/Down
    Received: 1/0
    Given: 0/0
    Someone has recommended an LM317 type chip... I'm looking at some of these such things that can run in Switch Buck Mode, looks like they oscillate on/off against a diode and inductor (inductors are a mystery to me) to pulse i.e. 18V 50% of the time and output basically 9V, somehow (this voltage adjustment must be the inductor's doing; a capacitor would just overheat and stabilize 18V).
    36V * 1.41 == 47.16, so I'd need a 50V LM317-type chip (there's a 60V one for 60 cents) ... also a $10 V meter, maybe a digital one, next to the adjuster, and a current limiter for that.
    Apr 2008
    Oceanside, NY
    1,649
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    A 2' x 2' plywood board with a typical power supply built-on to it with all of the PSU components on Fahnestock clips, and plenty of Fahnestock clips in a double-row arrangement works nicely.
    Some of you might need to look up "Fahnestock Clips".
    John R. Frondelli
    "Mediocre is the new 'Good' "
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,149
    Thumbs Up/Down
    Received: 241/1
    Given: 0/0
    Christmas day, 1954, I met my first Fahnstock clip. I been in electronics ever since.
    Last night I typed up a detailed post and then lost it.
    But AES sells nice glass epoxy boards with tube sockets and turrets. I have a few and they are cool. They come in both octal and 9-pin versions. The 9-pin ones come in single, two, and three socket models Here is the two socket, stock P-TB9-2-2
    And some of them come with a third row of turrets if you want.
    These may be more for the prototype stage than the initial breadboarding, but I think they are cool.
    Antique Electronic Supply
    Under vacuum tube accessories - epoxy terminal boards
  7. #7
    Noodle of Reality Steve Conner's Avatar
    Glasgow, Scotland
    7,251
    Thumbs Up/Down
    Received: 8/0
    Given: 0/0
    You need one of these
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  8. #8
    484
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    These are also nice.
  9. #9
    30,149
    Thumbs Up/Down
    Received: 241/1
    Given: 0/0
    I think you need to route the yellow wire a little closer to the white one.
  10. #10
    Apr 2008
    Oceanside, NY
    1,649
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Looks dangerous Steve. I LOVE it!!!
    John R. Frondelli
  11. #11
    Jul 2017
    British Columbia
    357
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    I do almost exactly the same thing. The minor differences are that I use 3/8" plywood, and #2 brass wood screws. No hammering is needed for screws - so I can add new screws as the circuit evolves, even with the board already populated. I use a small drill bit in a pin-vise to make a pilot hole for the screw.
    I mount the screws and components on the underside of the board, with the valves on top. That keeps heat away from the components. Also, when finished, I mount the whole thing with standoffs inside a cheap metal baking tray or cookie sheet, which provides a ground-plane and shielding.
    It works well enough that, for one-off projects, the prototype can become the finished product with no changes (other than adding a suitable housing, front panel, etc). Plywood of this thickness is very durable, and more than stiff enough to take the weight of reasonably-sized power and output transformers, and to cope with valve insertion-removal forces.
    If you don't have access to a table saw, Michaels (craft store) usually carries conveniently sized pieces of high-grade plywood that are perfect for this.
    -Gnobuddy
  1. Good prototyping board?
    By lowell in forum Theory & Design
    Last Post: 06-12-2010, 12:36 PM
  2. Help! Soldering on a new board
    By Rigormortis in forum Build Your Amp
    Last Post: 01-14-2009, 03:51 AM
  3. Replies: 3
    Last Post: 01-09-2008, 01:00 AM
  4. turret board vs eyelet board
    By clintonb in forum Build Your Amp
    Last Post: 09-22-2007, 07:44 PM
  5. Is the old board gone?
    By pupoholic in forum Pickup Makers
    Last Post: 08-01-2006, 10:06 PM
